Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
You cannot restore the key operator code for the Aficio 1060/1075. You can delete the code and then write new one . Follow the instructions and will be easy. 1. enter the service mode. 2. To enter the service mode press one after other the follow keys on the control panel of the copier. press the yellow key [ Cancel Modes] than press the number one after other [1]-[0]-[7] on the number keypad of the copier and than press and hold the red key [ Clear \ Stop] until on the touch screen do not appear the service menu after the service menu will appear press on the touch screen [Copy Sp] up in the right corner has a touch key [sp direct] press that key and press the follow numbers on the number keypad which are 7810 and then press "#' on the number keypad. on the screen will appear "execute" press the touch button and than by pressing "exit" several times you will exit from the service mode. NOTE: "PLEASE DO NOT TOUCH NOTHING ELSE IN THIS MODE IF YOU ARE NOT A SERVICE TECHNICIAN BECAUSE BY PRESSING SOMETHING YOU MAKE SOME ERROR OR OTHER PROBLEM" After clearing the key operator code you may enter new one.
here's the link;
http://www.allynint.com/
or contact on;
Allyn International
Sewing Machine Importer
1075 Santa Fe Drive, Denver, CO 80204
Phone: 1-800-525-9987
Fax: 303-825-5078
E-Mail: [email protected]
Hope this helps :)
If you are not in the USA then please ask again and specify where.
