main motor has failed to reach revolution within specified time- in other words - something is siezed solid and is preventing the machine from turning over into normal warm up operation-
suggest if you have recently replaced a toner cartridge/ fuser/ Image transfer belt then remove the new item and cycle the power without the unit installed. if tour machine warms up then complains about no cartridge then you have confirmation of the new unit being faulty-
if you are using 3rd party toners/ fusers then that could also be your problem. 3rd Party toners do NOT save money rather they will incur repair costs as they are not correctly prepared for re-use.
Please check if there is some error code appear in printer display. If you don't understand japanese then find someone who understand. No one can troubleshoot it without knowing the error message :).
If an error caused the printing to end abnormally or a malfunction occurred in the printer, then an error message code (***-***) is displayed.
If an error code not described in the following tables is displayed, or the problem persists even after you have tried the following solutions, contact the Customer Support Center.
Tip
If an error code is displayed, all print data of the printer as well as print data stored in the built-in memory of the machine is discarded.
Error Code: 127-212 Error Category: Print; Other Problems Cause: Detected an internal print check error by the FreeFlow Print Services Controller. Remedy: Remove and reinsert the command/video cable between the FreeFlow Print Services Controller and the printer. Power off and on both the printer and the FreeFlow Print Services Controller. If the problem persists, call the Customer Support Center.
*** extracted from my Fuji Xerox Color 560 Printer - Printing Systems User Guide
hello try to do this
press menu#1934 and right arrow key
disply show ready tech
press menu button and press left arrow key
display show new cartridge.press enter button twice.
then restart your printer.error message didnt display
What is the error number that comes up there should be a code that is displayed. Once I have this number I will be able to tell you why you are getting the error and how to fix it.
