IBM ThinkPad T30 Notebook Logo
Posted on Nov 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 2 512 cards installed and the computer only shows that I have only 512 installed and it should be 1 gig?? What would be the cause of this?
Anonymous
Level 3:
  • Master 1,481 Answers
  • Posted on Nov 16, 2010
Anonymous
Master
Level 3:
Answers
1481
Questions
0
Helped
312679
Points
4172
There could be many reasons,
1 Either the RAM slot is not working
2 or the RAM card(s) are not OK
3 or the RAMs are not compatable(not of the same specs)
Solution
1 Remove both the RAM cards, clean the metal joints in both the RAMs and the RAM slots
2 Remove power, remove all power source, remove power cables including all the battery
3 Keep presssing the power switch ON for a few mins, Do....ON... OFF, ON... OFF WITHOUT any POWER
4 Replace battery, power adaptor, power cables etc
5 Insert one of the RAMs in 1st RAM slot, power on, check if it's OK, Switch OFF, remove the RAM
6 Do the above process for the other RAM, now check if that works, use the same RAM slot
7 Now do the above two steps for the 2nd RAM slot
It will give you a rough idea of where is the issue.....either RAMs are not OK or the slots have issues or there is a compatibility issue among the RAM cards.....
Pls reply back and leave a feedback
Regards
Kris
4answers
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Trying to upgrade ram, only reading 512 instead of the gig i put in, can i reset jumpers or is there any other way. i don't have motherboard manual
you can only have the gig stick the board is older and can only utilize 1 gig at most take out the 512 and your gig will show up i promis
I just upgraded memory from 512 to 2 gigs, but the computer only shows 1 gig. why?
The other 1 gig is not properly installed oropushed in all the way
Problems with Foxconn 6100K8MA-RS Motherboard memory upgrade
This is an oldtime POST code memory error. Likely that ram is either installed wrong, bad RAM or the mobo doesn't like one of the memory sticks.
See http://www.computerhope.com/beep.htm.
You must count the beeps.
One of the ram isnt recognised???
This is likely a memory timing incompatibility. You can go into the BIOS settings of many motherboards and set the timing specifically for each RAM slot, but without knowing exactly which piece of RAM you have I can't tell you what to set it at. You could use the utility CPU Z, install one stick, run the utility and write down all the memory information, then install the other stick and write it down too. Then go into your BIOS and see if you can set all of your specifications to match the memory.
Of course if you could find someone to swap sticks with that would be easier. Some motherboards are more picky than others about which sticks they work well with, name brand manufacturers are more picky than aftermarket in general.
1helpful
Memory Error
You will need a new memory card, 1 gig or less, and not the new HS 1 gig cards. Look for a M type or get a 512 or smaller.
4answers
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Graphics upgrade
As long as you have a open vga, vga e, or pci slot in your computer you should be able to install a new video card. the Acer website says your motherboard supports up two gigs of ram, I am not sure how much ram you are running but if it is under 1 gig I would consider upgrading that also. as far as a graphics card goes get one that has at least 512 mb of its own ram so it dosent pull from your system ram as I am sure your current on-board card is doing. Another couple of hints are: if you are running Windows Vista you they call for 1 gig ram for optimal performance, also it is very important that you un-install any graphics drivers before you install new ones, and when you install the new card read the instructions completely before you do anything.
hope this helps
Carl
Memory/Graphic problem
This might have something to do with DVMT or Digital Video Memory Technology. Basically, the amount of video memory is dependent on the amount of memory installed. I'm not very familiar with acer system BIOS but try to look for VIDEO under system BIOS and try to select any fixed video memory if possible. you can also try to disable DVMT.
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
