SOURCE: Jazz DV179 Instruction Manual???
I had that camera and have some backed up files/manual I can send you. [email protected]
SOURCE: Deleting pictures from my camera jazz JDC31 Digital camera
Hi sjadl2840,
I presume you've already saved those pictures you want to keep in
another location and you want to flush everything in the camera.
Typically, you have a button on the back with a little trash-can
picture next to it. Pressing that will put you into Review/Delete mode.
You will usually need to use the up/down/left/right arrow keys to
navigate to select the photos you want to delete. Selecting the "OK"
or "select" button will select that photo for deletion. You will
typically have to confirm deletion for each photo, or before deleting
all (if your camera provides that option in it's programming).
These instructions are somewhat generic; if they don't work for you,
respond with a comment, and we can zero-in on your specific situation.
Beyond that, if I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
SOURCE: cant find a way to manually download arcsoft photo impression 4
not sure if its compatible with vista?? 1-800-983 7004..their web site is under construction....
x116 technical support
X140 customer service
SOURCE: i cant delete!
u no how u turn the camera on?? keep clicking that same button till it comes to the trash can and then press the capture button (the one on top from which u take pictures)
I cannot work this camera. I do not have a manual. Thank you.
