SOURCE: Hard Drive Problem
Sounds like your hard drive is crashed. You will most likely need to replace it. Before it gets totally crashed try to backup your important data while it is running.
Hope this helps you
SOURCE: Monitor / LCD screen unresponsive to computer.
From what you've told us, It sounds like your LCD screen. The first thing to do is to to beg, borrow or steal a desktop monitor and plug it in to the proper port on the laptop. Turn it on and bring the system up. If this works, you can be pretty sure that you have nailed the problem. Once you've confirmed the problem, you might want to try to open it up to check the LCD cable and connector. Disconnect and reseat the connector and look for any cuts or abrasion on the LCD cable. If these actions don't get the display working, you'll probably need a new LCD. If you need more help on this, just let me know.
By the way, you did a very good job of describing the problem. Kudos to you...
R-
SOURCE: Unable to get PC to boot
Does it have a floppy drive? if so, check if there is a floppy disk in the drive.
Let me know, and we can go to the next step.
SOURCE: I have a hp compaq nc8000 that is wigged out on
Hold your power button down until it shuts off. Turn it back on and let it scan to fix the problem itself. It may ask your permission to do this or automatically do it, just do it. Should fix the problem.
Switch On
your PC/ Laptop and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click
'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and
click Next
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '<' sign in the upper left hand
corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are
facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System
Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a
reboot.
After reboot your problem should be resolved.
Switch On
'System Restore'
click Next
reboot.
Switch On your
'System Restore'
click Next
reboot.
1. Open the Start Menu.
A)
Click on All Programs, Accessories, System Tools, and System Restore.
2. Open the Control Panel (All Items View).
A)
Click on the Recovery icon.
B) Click on the Open System
Restore button.
A
'System Restore' window will appear. Here you will have to check "Restore
A)
Click on the Next button
Now
you will find a window with Dates, Description and Type,
Note:
It is better if you could remember from which date you are facing the issue,
The
detail of that particular date should show "System Checkpoint" and
Now, Click on Next and System Restore will start. Click on the Finish button and windows will take a reboot.
If you feel that my answers have helped you getting
solution to your problems then please give a vote.
Thanks
