Maytag SAV5710 Top Load Washer Logo
Posted on Nov 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have water leaking from the middle bottom of washer, not leaking from hoses or water outlet
Anonymous
Level 3:
President:
  • Master 1,702 Answers
  • Posted on Nov 15, 2010
Anonymous
Master
Level 3:
President:
Answers
1702
Questions
0
Helped
766779
Points
5419
Sounds like the water pump, pull the housing and look at the bottom center for a oval shape with two hoses.I bet you find the leak there.......GOOD LUCK
Frigidaire Washer Model FAHE4044MWO is leaking from the bottom, what should I check first?
Hello Cicl, I appreciate your post!
If you have a water leak from under your Frigidaire washer it could be a possible problem with a faulty water hose, water inlet valve, or drain pump. Either one of those components could be causing a drain within your washer. Since it could be any one of these underlying issues I would suggest seeking assistance from a professional technician to get a proper diagnosis and repair. I hope this is helpful. -Matt
Amana tandem 7300
What does it mean when a washer leaks from the bottom?
The pump will have an outlet or drain hose, an inlet from the tub and may have a circulating hose outlet as well. If you have water leaking from the washer during a wash or drain cycle, check the area of the drain pump. Look for signs of a loose hose clamp or a leaking hose connected to the pump first. Washer Repair Diagnostic Leaking Water Amana Whirlpool NFW7300WW
1helpful
After the last wash yesterday the tub was dry. This morning there is water in the bottom of the washer tub.
2 possibilitiies here.
1- the water inlet valve/s are leaking past the seal as the the washer is stood, remedy, replace the valve/s.
2 If fhe outlet pie is connected toi the sink waste, then water could be syphoning back from the sink into the washer.
Remedy, lift the outlet hose up higher than the bottom of the sink waste outlet.
2answers
Water is coming out of the bottom of the washer
sounds like a broken hose ( drain hose ) -- or a loose fitting.
this could also be a cracked mixer valve ( if the water is running when washer is off ).
if you remove the back panel and start the machine and run cycles then you should see the cause of the leak very quickly.
c...
3helpful
Wahser is leaking water from the bottom.
the pump may be leaking, or a crack in the hose ,
My Ensigna washer is leaking water from the bottom during a cycle. Checked hoses feeding into the washer and there is no leak there.
maybe the outlet pipe inside the machine is split or the seal at the bottom of the tub has gone
Hoypoint aqxx149 not draining water and leaking
You need to check the outlet hose of the washer, make sure it is not kinked or restricted in any way.
Check the pump filter which is located behind a removable front plastic panel at bottom of m/c.
Unscrew the scews and remove the filter by unscrewing anti clockwise, be careful as there will be some water run out., clean filter and replace it
Check inlet hose for leak, and dispenser hose for soap blockage.
PLz rate my solution.
Thanks.
2answers
Leaking from bottom front
lean washer to back ..pump mounts just underneath 2 clips hold pump too motor shaft remove clips remove hose clamps ckd pump most likely suspect for leaks
1helpful
2answers
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
