SOURCE: Hotpoint sxs compressor stays running.
Fasnipe, it sounds like you are starting to lose the gas in the unit. Fairly soon, you'll see that the unit will fail to keep things cold. If it is less than 5 years old, you may have a warranty. If more, I suggest you get in a technician when the problem begins to impact the ability to keep food. You cannot fix this yourself.
SOURCE: NOT COOLING SUB Z 550
you have either a bad compressor relay or a bad compressor. disconect the power and pull the cap off the problem compressor and there will be 2 components that wires are hooked to. leave the wires on them but pull them off. the one with the most wires is the one that you wanna check. shake it in your hand and if it rattles like it has gravel in it then replace it with a new one. that part is your compressor relay. If it doesn't rattle then you have a bad compressor. The other one with one wire is the overload. It is probably white depending on how old it is. Let me know your modle # and I can get you a part #.
