I recently bought a used ipod. It doesn't appear in itunes when I plug it into my computer. I wanted to reset it, but since it didn't connect to itunes I tried first putting it in disk mode. This worked. I then plugged it into my computer. It popped up on itunes with a message that said my ipod was corrupted and it needs to be reformated. I pushed the restore button. I progress bar appeared but soon afterward an error message popped up with an unknown error. I think the number (1418) was listed. I'm not sure if that was the correct number. Is there a way to fix this problem. I would just like to retore it.
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
For this FREE answer, Please take time to rate me
I would like to advice you that, Install a iTune software & just synce you ipod with your PC files & it will get music. Copy paste is not working in ipod you must have to synce ipod to play music.
Go on to itunes and plug your mp3 in to your computer and download it and salect which tunes you want. If it dose not work
there is somethind wrong whith your mp3
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Plug the
usb cable into the Ipod and NOT into the computer. Hold the
Home Button down for 5 second (do not release it) Then
Press and hold the Power Button for approx 10 secs (count them out) Your iPod
will reboot. Release
the power button and continue holding the Home button for an additional 27secs. You may
see the screen go blank or not. Plug the
USB end into the computer with itunes open. Your ipod
will mount in recovery mode. Restore
it and Your all set.
if you need any further help let me know. Good Luck
The 5 Rs: Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with iPod shuffle. Try
these steps one at a time until the problem is resolved. If one of the following doesn’t
help, read on for solutions to specific problems.
â Reset iPod shuffle by turning it off, waiting five seconds, and then turning it back on
again.
â Retry with a different USB port if you cannot see iPod shuffle in iTunes.
â Restart your computer, and make sure you have the latest software updates
installed.
â Reinstall iTunes software from the latest version on the web.
â Restore iPod shuffle. See “Updating and Restoring iPod shuffle Software” on
page 26.
same probelm too i try using a method on apple forums but no help plz help
the same problem. And I got the ipod used too.
when I conected the 80 gb i pod to I tunes corruted i pod came out
