SOURCE: i purchase a kingston 32 GB pen drive but it nt work
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove Hardware icon and then click on USB flash drive you want to remove)
SOURCE: hi.... i hav 2gb kingston n it does not b format
2. Format
SOURCE: Kingston DT 101 II Usb Device become SKYMEDI USB drive
2. Format
SOURCE: Kingston DT100/2GB Detection and Failure
No need to worry, I will solve your problem follow this link to find how to solve it http://www.fixya.com/support/r4391734-usb_flashdisk_pen_drive_write_protect or you can see my blog, http://adhiwahyudy.blogspot.com, but this blog use indonesian languange
SOURCE: 8 gb kingston Data Traveller showing zero disk space
All you need to do is to format the Pen Drive.
Open My computer.
Right Click on Pen drive.
Then click on Format. You will get different options like quick format or such.
Select the option that says complete format.
Once you format the drive you will be able to use it.
Thanks
Jimmy
insert 32 or 2 GB USB go to control panel administrive tools computer management disk mangement you can defragment this USB drive or you can right click select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
hope this helps
