LG Monitor L194WT - Indicator Lights Flashing
When monitor goes to sleep, the power lights flash oddly ... purple and blue, in two different rhythms. At that time, monitor's on/off switch doesn't respond. (On/off switch DOES respond when monitor is working (solid blue light) or in power save (yellow light). When lights are flashing, monitor also does not come back on when mouse is wiggled and keys hit.
If I attempt a hard boot (did it just once) the monitor came back.
So, is this problem the monitor or the computer??
Sorry to be so dense....
  • cp556 Jun 19, 2008
    OK....so I'm trying the fix in two steps: first, I changed the Power Setting Options as you suggested.
    If this doesn't work by itself, I'll add the blank screen as screensaver.
    And if THAT doesn't work, I'll go buy a new monitor ... lol. Does that sound like a solution?? I am happy that the problem is not the computer itself.....a monitor is cheaper and easier.
    Ohms ... you are WONDERFUL. Thank you. I just found the warranty (3 year!) and original receipt (1.5 years ago) so it should all be good. THANK YOU THANK YOU......
  • 1,879 Answers
Sorry - i posted my response at the original thread : )
Comment by ohms, posted on Jun 19, 2008
Definitely it is not your computer. When it was given the signal to go OFF, it did but like completely off.
Comment by ohms, posted on Jun 19, 2008Oh one more thing, if the monitor still exhibits same issue after setting your Power Options as displayed above,
check your warranty with that monitor and exercise it.
Yep u got it ! warranty or new monitor
Posted on Jun 19, 2008
  • monk3ybidzness
    monk3ybidzness Jun 19, 2008
    Thank you for using our service.
    FixYa.com - Consumer Electronics support, repair, manuals, faq, problems and solutions
SOURCE:
I have a acer.x223w when,it powers up the.screem stays black, n i get a blue blinking light on.the bottom
I disagree with ikkenom only due to the symptom of the flashing blue light. This would indicate to me that the monitor is not getting any display signal and is in sleep mode at least the is what happens on my Samsung monitor. Used to be that they use a two color led in the monitor, green when ON and getting display signal and amber or orange when in sleep mode. I would check the computer by trying a different monitor. If you have a second monitor, great, if not, maybe a friend will let you bring your computer over and try the computer with their monitor. Could also be a display adapter setting. Do you get any change when you first turn on your computer? i.e. Do you get the BIOS or manufacturer screen when first turned on? Also if you disconnect the monitor cable from the computer and power cycle the monitor, do you get a No Signal display for a few seconds before the monitor goes black and the blue light starts flashing?
Let me know what happens with the testing above or if you need further instructions to carry out testing.
Thanks, Jim
Feb 21, 2013 | Computers & Internet
hi n hello
tried restarting the computer ?
Jun 19, 2008 | Computers & Internet
Lg 1752s goes into power saving mode when pc is turned on
Hello Alan,
That is actually not power saving mode, the flashing power light indicates the power supply is not starting up correctly and keeps shutting down and trying again. This is a very common symptom of a failure of the capacitors on the power supply board. The L1752s uses the AIP0157 power supply board which is the same board the is used in several LG monitors such as the L196WTQ and L194WT. Here is a link to a repair guide for the L196WTQ that shows what capacitors to look for and replace on the power supply board to bring the unit back to life.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
May 15, 2012 | LG L1915S 19" LCD Monitor
My samsung RV511 laptop won't boot and the monitor keep on flashing on and off but the power indicator still ligths on
The monitor keeps flashing on and off? Or does your system keeps trying to reboot which causes the monitor to go on and off. Does the screen turn Blue before it goes off?
Apr 10, 2012 | Computers & Internet
My L194WT -SF WONT WORK NO POWER USED SAME POWER LEAD ON DIFFERENT MONITOR NO PROBLEM
Hello Steve,
The most common problem with the L194WT monitors is a failure of the power supply board. There are parts called capacitors that fail and can cause the issue you have. Sometimes the power light will just flash, sometimes it takes several minutes to display a picture or even a wavy picture, all of these issues indicate a failing power supply board. These boards can be repaired if you can do a little soldering. The L194WT uses the same power board as the L196WTQ and we have a step by step repair guide with dis-assembly instructions available at http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/ Look over the guide and check your board to see if your capacitors have bulged and need to be replaced.
I hope this helps, if so please rate our solution.
BuddyMc
Aug 07, 2011 | LG L194WT 19" LCD Monitor
Blank screen after monitor sleep just blue flashing light
First of all you can change the Power Settings in Control Panel. You can configure as you need. I mean after how much wait it should go for sleep n all.
If it takes 5 min. to wakeup that means you have so many applications running that system cannot manage or RAM is small.
The final solution just remove the Display drivers and reinstall it.
After removing please restart the system once to proceed further
Aug 03, 2009 | HP Pavilion dv9000z Notebook
LG Flatron - Power button flashing blue
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Apr 20, 2009 | Computers & Internet
Monitors goes to sleep when powering my PC
In My Computer, find the icon for Display and configure the energy saving features so that your monitor doesn't sleep as soon.
If you need more help, I will be more than happy to assist.
Apr 07, 2009 | Relisys RLT1720 17" LCD Monitor
Monitor went to sleep and won't wake up
my monitor comes on for a few seconds and then shows monitor going to sleep and then it does. can you please help me as i really need my computer.
many thanks
barneytina
Aug 11, 2008 | Princeton Digital VL17151 17" Flat Panel...
Open Questions:
Computers & Internet Logo
1,563 people viewed this question
Ekse
Alun Cox
