Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
Posted on Mar 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pvs50-36fv just looking to find the manual on-line and to see the problem codes in a print-out. We have a similar problem to: By acmesser on Oct 04, 2010 Rheem Power Vent PVS50-36FV..Constantly goes to lock out..Unplug it turn it off . wait and turn on but sometimes in a day or a week again goes out .\r\nWhat to do?? MY WATER HEATER: Model - Rheem PVS50 36FV Ser# - 0906505102 Item # - 970103205 Alt - 0-5000(0-1524m) The heater is 3 years old - I first cleaned the inside and gently brushed the heat sensor (thermal couple?) with green soft spongy sanding pad. It started working for short periods but constantly went out. It restarted with electrical cord-plug removed and reinstalled. I then replaced the entire heat sensor unit and cleaned the gas chamber again and it worked for about 6 months. I frequently checked the vent pipe and found no obstructions. It is now back to stopping every 1-2 days and the code light does not change from constant green blinking. Any new ideas for this?
Marty Warge
Level 3:
Master:
  • Master 561 Answers
  • Posted on Jan 22, 2020
Marty Warge
Master
Level 3:
Master:
Answers
561
Questions
Helped
187949
Points
1881
I think you just need to buy the best electric tankless water heater and read more about them. People are rarely interested in such household things but in reality, they are very important and we'd better know of them. So, reading reviews is a good way.
glassy sound
Level 2:
New Friend:
  • Expert 39 Answers
  • Posted on Jan 21, 2020
glassy sound
Expert
Level 2:
New Friend:
Answers
39
Questions
0
Helped
49165
Points
107
Usually it is possible to find a manual just by googling. if not, the company definitely has tech support and you need to find their number. Most likely it's on the official website. Just call and ask the question.
Kevin.
Level 2:
Sergeant:
  • Expert 256 Answers
  • Posted on Feb 05, 2018
Kevin.
Expert
Level 2:
Sergeant:
Answers
256
Questions
0
Helped
75470
Points
517
Google,put model number into search followed by " user manual " , should help you find the instructions.
1 Related Answer
Douglas Jensen
  • 494 Answers
  • Posted on Oct 04, 2010
SOURCE: Rheem Power Vent PVS50-36FV..Constantly goes to
Call the manufacturer phone # that is printed on the water heater. You probably have the model that requires a retrofit burner with reset button to be installed to fix this issue. You will also have to clean out the bottom screen filter below the burner when you change it out. They will need the model # & serial # to check if yours needs this. Douglas
Resolving an error code 51 on Noritz nrc98-dv lp tankless water heater
I need the full model number of the water heater to pull the manual on it for you.... so far only an error code 61 is shown. sometimes a 6 can look like a 5 on a digital display if it's a 6 then error code 61 is bad fan motor or printed circuit board that sends power to the fan motor.Get me the full model number, we can go from there
Keep getting error code 10 for our rinnai rl75 tankless water heater how can we fix this?>
Go to the manual or go on line for the manual and look up the code and its meaning.
Beep codes
Get the manual for it on line and look up the beeping meaning and the reaqon for the priority lite.
Whirlpool 6th sense natural gas water heater 50 gal. Bought brand new today. Upon installation, discover low gas pressure running to unit. Turned out that gas line had under ground leak so had to turn...
1) Be careful before you Call Whirlpool 1-877-817-6750.
Be careful what you report so not to void warranty because installation protocol was not followed. Whirlpool will cover gas control valve, and possibly the installation of valve which takes about 15 minutes and does not require emptying water heater.
************So make sure you report installation that is consistent with installation shown in manual.
2) Whirlpool will also answer this same question later today with invitation to contact them.
3) Copy following link to identify gas control valve, and download service manual:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
4) If dirt or debris gets into gas control valve, it will cause it not to work. Such as broken gas line. Debris can enter gas line.
Or if too much pipe dope was used on gas connection, or stray teflon tape got into line and then into valve, or end of pipe got dirty during installation, and then dirt got into gas control.
Take off gas line and use vacuum cleaner to see if something can be removed by suction. Clean up the joints.
5) It appears you have ordinary Honeywell gas control valve on atmospheric vented water heater with 9 year parts-labor warranty..
Unknown error code, so it is hard to look up solution in service manual.
Add a comment if you want expert to look up error code in service manual.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Working on a N1321-ASME unit installed in a Taco Bell. Getting error code 21. Unit gas pressure is at 8.5wc and manifold pressure spikes to 2 when it come on but unable to see what it remains at because...
I recently had a similar problem with my N-132M-ASME heater. The unit would come on, then shut down and flash Error Code 21. According to the owners manual, that code indicates the unit is not getting enough air. I tried vacuuming the unit, blowing it our with air and checking to be sure the exhaust lines were clear. Nothing helped. A service technician came out and recommended I descale the unit and clean the burner. I did this but the problem did not go away. He also suggested I replace the Burner Sensor. It's not an expensive part, around $20. I ordered the part and have not had a problem since I installed it. Hope this helps.
I have a Bosch AquaStar AQ-125-BNG tankless water heater, and for some reason when it is heating the water, it seems to get exremely hot and the heat is radiated back into the cold water supply line and...
Tankless should never be installed with plastic pipe, PVC or CPVC etc.
Before calling service technician, open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
My paloma tankless gas has a error code c2 11 c4 12 why
Open following link for useful troubleshooting information:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error code 11 is 'No ignition'
http://waterheatertimer.org/pdf/Paloma-Tankless-Error-Codes.pdf
Ensure you have gas to the appliance.
Ensure gas type and pressure are correct.
Bleed all air from gas lines.
Ensure gas line, meter, and regulator are sized properly.
Ensure appliance is properly grounded.
Check gas solenoid valves for open or short circuits.
Ensure igniter is operational.
Check igniter wiring harness for damage.
Error code 12 is 'Flame Failure'
Ensure flame rod wire is connected.
Check flame rod for carbon build-up.
Check power supply for loose connections.
Check power supply for proper voltage and voltage drops.
Disconnect remote control.
Disconnect and re-connect all wiring harnesses on unit and PC board.
Ensure proper venting material was installed.
Ensure condensation collar was installed properly.
Ensure maximum vertical vent length does not exceed allowable limits.
Ensure maximimum horizontal vent length does not exceed allowable limits.
Range of causes are part failure, gas pressure loss, air in gas line, improper installation of gas line or vent, 120V power to unit is disrupted or unit not grounded, circuit problems, venting problems, remote control, wiring to PC board, board failure, carbon build-up on flame rod, short circuits on gas valve solenoids.
The fact that you have error code tends to eliminate your plumbing as culprit, the error code does not mention air supply, otherwise it looks like every possible cause is on the table.
Add a comment with your experience so other with same-similar problem can benefit.
Unit wont run and thers no error code
1) Rheem offers on-line chat, which you rarely see for typical tank-type water heater
http://www.rheem.com/products/tankless_water_heaters/customer_support/
http://www.rheem.com/hrc.aspx
2) Call local service technician, and put that person in your rolodex-wallet for future help.
When technician arrives, ask that person for tips and tricks keeping unit working with regular maintenance.
They will gladly offer yearly service.
3) Read manual several times get accustom to yearly maintenance required for tankless water heaters. Tankless water heaters are maintenance heavy. All costs are energy.
4) Read manual several times and notice word troubleshoot appears many times.
Since tankless are complicated machines, many internal and external factors can affect operation, especially as unit ages.
5) Look at label on unit to identify exact product number. Identify same/similar product at Rheem, and become familiar with Rheem website
6) Read other question/answers at fixya about Rheem tankless to become familiar with the tankless era
http://www.fixya.com/tags/rtg_74pvn
7) Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
8) Add a comment for more free help.
Looking for a flow sensor for Bosch Aquastar 240 FX
Open following link for Bosch tankless troubleshooting resources including parts, Bosch contact information, typical manuals, error codes, tech support, fuel-saver calculator, water heater forum, fixya links, disclaimers, and for finding service technician.
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
