Lanier Expert
- Posted on Nov 15, 2010
Re: I have a lanier 7328/7320. It reads side door open on...
How are you? This is a problem with front door switch.
Remedy
- Place the machine on a level table and make sure all the four stands are landing freely on this table.
- Check that the front door notch that closes the door switch is not broken and if it is replace that particular door or modify the notch.
- Make sure the upper half of copier is well locked with the lower bottom part.
If all the above is correct, and still reads open, replace the door switch.
Good luck.
Its not the front door its the side door
