If detergent and scrubbing is not working try a solvent ... but if that does work directly on the stain go the next step and create a poultice by saturating an absorptive material (such as kitty litter or sawdust) with a strong solvent (acetone, xylene, lacquer thinner, or MEK) and then smearing the material over the stain. Cover the poultice with plastic, and let the process of osmosis take over. The solvent will break down the oil, and the absorptive material will suck it out of the concrete. Part of the challenge with oil related stains in concrete is that the material has migrated below the surface into the concrete. The poultice process does takes time and may not be cost-effective or practical for removing large stains.
SOURCE: Samsung WF-J1254(V/S/C/R) leaks water around
I have finally found a reference in Samsung's own knowledgebase, online in which they indicate that this appliance was designed for European water pressure systems and that in the US and Canada, often water pressure can be much higher than in Europe (although the manual says it is good for 800kpa, which is a darn sight higher than they use in Europe, I think European domestic supply is regulated to 400kpa).
Whatever the case may be, I have noticed that my house has what appears to be rather high water pressure (subjectively of course). So, first I checked the leaking with it set to a cold only cycle, and low and behold, greatly diminished (since it was only drawing water from one line, hence a lower volume of water). Then I closed both supply taps about 2 thirds the way, and voila, problem is gone.
It makes way less noise now when filling, and I cannot really tell that the washtime has been extended excessively due to the longer fill times?
Would love some feedback if this fixes your problem?
SOURCE: Oil leaks onto the manifold pipe
I had the same problem check the oil sensor switch located above the manifold it is electronic with to wires I leaks when bad
SOURCE: Engine oil get less every two weeks in my pajero 4m40
Diesels do lose a little oil out the blow-by tube. If the engine temp. is higher then normal then you will lose more then normal amounts. If you are not leaking it then you are burning it, Possibly worn rings, head-gasket, or oil leak inside turbo. 68 MPH and higher doesn't sound unusual, is the engine still stock?
SOURCE: Water Leak in Passenger Side Floor Vent Area after car wash
Unless this happens in the rain as well, I would not worry about it. Likely in the car wash, far more water is coming in than the normal drain system can handle, therefore causing it to overflow. If you do have a drain obstruction, find the drain hose (small right angle hose on firewall passenger side) and roll it in your fingers to clear it.
