SOURCE: LG Diswasher model LD-14AT2
NEED TO SORT OUT LEAK FIRST AS THIS HAS ACTIVATED YOUR SUMP LIMIT SWITCH. THE CYCLE WILL NEVER PROCEED OTHERWISE.
SOURCE: Dishwasher
If you have confirmed power to dishwasher, you are pobably looking at a control board. I have only run into this one time on a LDS5811 so far. Parts on LG dishwashers have a two year warranty. You have to dissassemble the door to replace the part.
SOURCE: Bosch Dishwasher SMU 2046
It doesn't work at all
If your dishwasher doesn't work at all, check these:
Power from the house
Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring
Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch
Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
SOURCE: LG LDF6810ST Won't Turn ON
If you are still having the problems you describe and especially is you are getting a leak from the lower left door panel, please provide the model number and the serial number.
There IS help available if you provide the info.
Please report back. Thanks!
SOURCE: LG LDS5811BB Dishwasher
Some of the LG LDS5811 had problems with the wiring harness in the door panel. This is nothing to mess with unless you have disconnected the DW from power.
You can open the door panel by removing the screws around the inside edge of the DW. Or, better yet, firmly but politely contact LG service and tell them you are aware of LDS5811 dishwashers having these symptoms being caused by _melting_ wires in inside the door panel. This is true and even if the DW is out of warranty, LG should fix this problem at no cost to you.
Good Luck!
