Lexmark P6250 All-In-One InkJet Photo Printer Logo
Posted on Nov 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Getting error code 2200 on Lexmark P6250 Photo All-In-One InkJet Printer. Programme asked to refer to user guide. Error code not in user guide. Unplugged printer while on. Restarted PC then replugged printer to power. Rebooted PC then Error message appeared. Unplugged USB cable and replugged USB cable. Error message appeared. Turned off PC and printer for 30 minutes then replugged printer to power. Error message appeared. Prints OK.
Anonymous
Level 2:
Genius:
  • Expert 1,325 Answers
  • Posted on Nov 15, 2010
Anonymous
Expert
Level 2:
Genius:
Answers
1325
Questions
Helped
344447
Points
292
Hi
here is what i have found -- follow to all instructions accordingly
although its for another model, these isntructions apply according t their techsupport i spoke with
.Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2.
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
here is where i found the error http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&question=2200 error#1
hope this helps -- God's speed
Error 2200 - not explained in manual
unplug the power pack in back for 30 seconds power back on an should work.
1helpful
2200 error
The 2200 error message on the Lexmark P6250 All-In-One Ink Jet Printer indicates a scanner stall or jam. Please refer to this link - http://bit.ly/aAy3bU for the steps that will help you resolve the issue and clear the message. If the error is still the same I would strongly suggest that you contact Lexmark Technical Support.Thanks.
4helpful
2answers
Lexmark P6250 Printer error 1203 - Consult User Guide
It is a hardware printing problem . Try to clean contacts in printers in cartridge holder by alcogol and elastic rubber. it may become dirty an poor contact. after this you can try this:
Put some layers of the sticky tape on cartridge to improove force of contact.
Installation disk for the Lexmark p6250 all in one printer
Here is the link:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
if you receive any error message while downloading plz let me know the exact error message.
What is error 2200?
i had error 2200 on my X7170 lexmark....i turned it off.uninstalled the lexmark software in uninstall/add programs in the control panel.restarted my computer.installed the software again....then worked like a charm....hope it works...peace.
1helpful
Lexmark P6250 Error 2200
This is a problem with your scanner. See if this article is helpful. http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:537:0:0&framed=&docid=ENUS24402&relevance=0
Error 2200 on a Lexmark P6250
This is a scanner error. The light bar that goes back and forth during a scan is getting stuck for some reason. You might also double check your cartridges. There is a complete article about this on the Lexmark website at: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:462:0:0&framed=&docid=ENUS24402&relevance=1 The user's guide should be installed on your computer (Look under Lexmark 6200 Series in your Start Menu) You can also find the manuals at http://www.lexmark.com/publications/eng/6200/index.html
1helpful
2answers
Lexmark p6210
I have an error 2200, how do I solve it? please help
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
