Texas Instruments TI-30XA Calculator Logo
Posted on Nov 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I use the ti-30xa to find cube root, 4th roots, and 5th roots?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Nov 14, 2010
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442133
Points
622693
Use the x-root function, which is the 2nd function of the y^x key located just above the divide key. For example, to find the cube root of 8, press 8 2nd x-root 3 =
1 Related Answer
  • 102366 Answers
  • Posted on May 27, 2010
SOURCE: Finding a cube root on calculator
You can calculate cube roots by using the cube root function (the 2nd-shift of the 0 key). You can calculate arbitrary roots by using the x-root function (the 2nd-shift of the y^x key, just above the divide key).
How do I use my square root, cube and 5th powers on the calcalatar?
Use the y^x key just above the divide key. For example, to raise 2 to the 4th power, press 2 y^x 4 =
6+3 radical 2
If you mean 6 plus cube root of 2 then press
6 + 2 2nd [cube-root] =
The cube root is the shifted function of the 0 key.
6+3racical 2
3helpful
How can I find the square root of 39 on my ti-30xa? Also I would like to know how to find the cube of 9482... Help
Square root of 39: Press 3 9 [square-root] =
[square-root] is the key just to the left of the divide key.
Cube root of 9482: Press 9 4 8 2 2nd [cube-root] =
[cube-root] is the shifted function of the 0 key.
For other roots, you can use the [nth-root] function, the shifted function of the key above the divide key. For example, to calculate the fourth root of 16, press 1 6 2nd [nth-root] 4 =
How do i do radicals expressions on a TI 30XA
On your calculator, in the 4th column and third row down you should see the root x symbol. In order to do a radical, just press a number and then press the root x and you shall get the square root of your number. Now in order to do this for cubed root, fourth root, etc, you have to hit the number you want to put in the radical, the 2nd key, look for the y^x key in the last column second row, and then the number outside the radical. For example, if you wanted to do the cubed root of 8, you would hit 8, 2nd y^x, 3, and you should get 2.
4helpful
2answers
How do you calculate the cubed root of a number or 5th root of a number?
For cube roots, use the cube-root function in the MATH menu. For example, to calculate the cube root of 8, press MATH 4 8 =
For other roots (including cube root), use the xth-root function in the MATH menu. For example, to calculate the fifth root of 32, press 5 MATH 4 3 2 =
5helpful
How do you get to the 5th root
xth-root is the shifted function of the x^y key, just above the divide key.
Example: to compute the 5th root of 32, press 3 2 2nd [xth-root] 5 =
6helpful
I need to find the cubed root of a number and my calculater doesn't have the symbol , for instance I need the cubed root of 49.7
The cube root of 49.7 is equal to 49.7 raised to the 1/3 power. You can take the log of 49.7, divide it by 3 and then find the antilog of this result. Or as below:
Cube root 49.7 = Antilog ( log(49.7) / 3) )
17helpful
3answers
How to get the square root using a ti-30xa calculator?
Come on now....there are dedicated "square" and "square root" keys on the TI-30XA....
Enter your number e.g. 4, then press the "root x" key to get 2...
Press "x squared" key to get the square of 2 = 4
There's the even more useful "y to the power x" key and it's inverse "xth root of y" key.
E.g. Enter 2, then press the "y to the power x" key, then 5, then =, answer is 32 (2 x 2 x 2 x 2 x 2). Starting with 32, pres 2nd then the "y to the power x" key, then 5, then =, answer is 2, the 5th root of 32....
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
