Watches Logo
Posted on Nov 14, 2010
I have a guess steel watch , and i have set my date and time right , but i cant put the day right , so monday or tuesdag for example.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1592
Points
Advance the watch time 24 hours to change to the next day. keep turning until it reaches the corect day of the week, then reset the correct time and date.
  • Anonymous Jan 15, 2013
    Thanks a million it worked perfect for me.
My Timex Marathon WR50M watch says 3/2 but "MO 2" instead of the correct "SAT 2". How do I fix this? (Problem started after Feb. 29, 2024.)
Question edited to add maker.
Reset the day in the settings. My guess is that you are in the wrong year.
Months and Years having Monday the 2nd
Time and Date https://www.timeanddate.com > weekday-monday-2 Monday, March 2, 2020 · Monday, November 2, 2020 · Monday, August 2, 2021 ; March · November · August ...
https://www.google.com/search?q=timex+marathon+wr50m+manual
MARATHON® DIGITAL - assets - Timex
Timex US https://assets.timex.com > manual PDF Feb 13, 2020 - Please read instructions carefully to understand how to operate your Timex® watch. FEATURES AND BASIC OPERATION. Your model may not have all ...
19 pages
Instruction Manuals, User Guides & Downloads
Timex CA https://timex.ca > pages > watch-manuals Instruction Manuals, User Guides & Downloads. Search for documentation for your Timex ... Features: Standard analog products, including Timex Q Reissue, Marathon .
Mar 02, 2024 • The Watches
1helpful
The date and day are incorrect on my dakota atomic watch; how do I reset these please ?
if just time is off by one to three hour(s) , you need to ck your time zone settings , if the day is off by one day you need to wait 24hrs keeping watch in a good view of the sky (not locked in a metal box) it should auto correct itself to proper day when it receives the radio signal for two time cycles (24hrs)
How does its year calendar work?
The day at a glance calendar system used in this Orient watch, has been used in a number of watches over the past 40 years, perhaps most famously in the Wittnauer "2000" watch (which Orient actually made for Wittnauer under contract). Orient itself has used this system in a number of different styles of watches. Note that the daily date window is separate from the day of the week / month at a glance system; the date window is driven in traditional fashion by the movement.
The day/month at a glance system is based on a single disc inside the watch that is manually advanced by the user. If you look at the top of the watch, where the months are listed, you'll see little two-digit numbers. These represent different years--"04" refers to 2004, "11" to 2011, etc. To get the right days of the week at the bottom of the dial, you move the appropriate year under the current month. That will line up the days of the week--Monday, Tuesday, etc.--with their correct dates. You may see the same year repeated more than once on the upper part of the dial because the calendar has a specific pattern that can be replicated.
On older watches using this same system, the top pusher was used to adjust the date window, and a separate winding knob controlled movement of the year/monthly calendar disc. On this specific watch, which I have not handled in person, I cannot see a separate crown to adjust the date, and so I am guessing that you would pull out the set stem part-way to engage the disk setting mode. This would make sense because unlike the date window, where the date is always advanced, the year must move both backwards and forwards to align with all the months in a given year--you'll see that January and October are in the same place on the dial, for example.
If you're interested, here's an example of a vintage Orient that uses this same system for its calendar. Note how the monthly calendar and year/month alignment are flipped from the watch you asked about. Please note that I have no connection with this web site, make no endorsement as to the price being asked for this watch--but it has a nice picture of a classic Orient:
http://forums.watchuseek.com/f30/$128-all-steel-orient-perpetual-calendar-xl-case-vintage-watch-526811.html
On a final note, you'll see a number of people refer to these as "perpetual calendar" watches. That's not accurate. The year / days of the week disc holds about 20 years of calendar information. After that, the disc is no longer accurate, though you can easily keep aligning the monthly calendar just be referring to a printed calendar and adjusting it that way. For a period of time (not sure if they still do it), Orient would accept older watches with this system and change out the old year/day wheel with a new one that went further into the future.
I can't set the day in my guess g13534g
Hi, You just have to release the crown out then keep on moving the crown clockwise untill you get the right date. You only have to set this once then it will keep the correct day for you as expected. Make sure you have the right time and date once you are done.
Hi, My watch shows the day as i 1day in advance.For example if today is Monday it will show Tuesday. Though i can change teh time and date but not able to change the Day of the week. Cananyone...
THE SETTING FOR THE DAYS ARE AUTOMATIC DEPENDING ON THE YEAR YOU FEED. IT MAY SOUND ODD BUT PLEASE CHECK THE YEAR YOU ARE FEEDING I.E IS IT 2010 OR 2011. IF IT IS 2011 THE DAYS WILL BE ONE DAY ADVANCED. IF STILL THE PROBLEM PERSISTS ASK THE RETAILER /COMPANY TO REPLACE THE WATCH, IF IT IS UNDER WARRANTY PERIOD.
Dec 24, 2010 • Watches
2helpful
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
1helpful
I have an automatic watch that shows the day of the week, I can't set it so that it changes from day to day correctly. I've changed it to correct day right after midnight and by the end of the day, it's...
hi,
first you kepp the day and date set yesterday's , for example today is 31st and monday so you set 30th and sunday , now keep rolling time by key till day and date has complitaly changed,remind that do not roll anty clock, it may be damages to your watch,now when you get change day and date its a midnight of 31st and monday, now set the time and get started ,
3helpful
Change day but not date on Timex Expedition
HI..
HERE IS STEPS FOR SETTING OF YOUR WATCH... STEP3 EXPLAINS THE SETTING OF DAY,DATE.....
  • Step 1 Push in the lower right button until you see the seconds flash. Press the upper right button to run the seconds display down to zero. Push the bottom left button to get into the mode to set the hours. Press the top right button to scroll through the numbers. Watch that you choose a.m. or p.m. correctly.
  • Step 2 Press the bottom left button to get into the mode to set the minutes. Again, push the top right button to scroll through the numbers until you reach the correct time.
  • Step 3 Repeat the process from Step 2 four times to set the month, date and day of the week and to change to military time if you wish. Push the bottom right button to save your settings. You'll notice the colon between the numbers will start to flash.
  • THANK YOU
  • 62helpful
    13answers
    Prospirit watch
    in order to SHUT OFF THE ALARM:
    go to the normal time setting, where nothing is flashing. then press and hold reset. then the time you want the alarm on shows up. in order to turn the alarm off press start...press start again to turn it on
    May 15, 2008 • Watches
    14helpful
    3answers
    Changing the DAY on this analog watch.
    Turning it backwards didn't work on my watch. I ended up winding the time ahead several days worth to show the right day of the week (being careful to turn it to the correct 9 o'clock of the day, for me is was the first for morning.) Then I could go ahead and change the date using the first click postition of the stem.
    I see that light bulb going off and you whispering "why, of course!"
    Dec 03, 2007 • Watches
    Top Guess Watches Experts
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Guess Watch Expert? Answer questions, earn points and help others
