NRS Hoveround MPV 5 - Used Power Wheelchair Logo
Posted on Nov 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need an owners manual. I have had the hoveround charging for approximately 36 hours, it seems to turn on but does not move.
Anonymous
Level 3:
  • Master 692 Answers
  • Posted on Nov 14, 2010
Anonymous
Master
Level 3:
Answers
692
Questions
0
Helped
288828
Points
1801
PK 36 hours charging is too long you will damage the chair and the batteries. You shouldn't have to charge more than 12 hours and never more than 24. If the batteries are weak the chair might power up but you don't have the power to energize the motors. If you have a digital voltmeter set it to 200 volts dc and plug the leads into the two outter holes of the charger port located on the joystick. You should be reading 25-27 volts with the batteries fully charged. Anything less than 20 volts will not be enough to power the chair. Hope this helps you
  • Anonymous Jun 28, 2011
    Regarding your Hoveround ?..If you purchased it from Hoveround, you should contact Hoveround directly. They made the chair. They will probably service it for you, and provide any detailed information you'll need. Go to their website http://www.hoveround.com) and see the Contact Us page. But, if you bought your chair used, well...maybe they will still give you some help.
2answers
1helpful
Online owners manual for Hoveround MPV5
The full manual is not available online. It must be purchased directly from Hoveround for $20 plus shipping. Please call 800-964-6837, you will need the serial number from your power chair, located inside the manual brake release above the footrest.
Need a owners manuer for hoveround mpv5
Contact Hoveround at 800-964-6837. If you are not the first owner of the power chair, you will need to register your chair into your name so that a part order can be created. Manuals are $20 plus shipping. To register your power chair, give them the previous owner's name or the serial number, which is located in the opening for the manual brake release just above the footrest.
Hoveround wont move
Make sure the batteries are fully charged, all the connections are secure, the fuses are intact, there are no flashing lights and that the two black manual brake release knobs are in the upright position (located just above the footrest.).
1helpful
The chair will not do anything.It shows the battery as fully charged and and that is it. It was given to me by my mother in law when she passed away because I am also handicapped but had lostb the owners...
When you connect the charger, if the light goes to red to green within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced. This can happen if the power chair is stored without being charged for a while. Batteries retail $75-$150 each depending on the model and brand, you will need two of them.
I was gifted with a Hoveround MPV 5. It was a
Depending on your use, you need to plug in the batteries to charge at least 8 hours over night.
1helpful
2answers
Need manual for hoveround mpv4
Hoveround doesn't publish the manual online. Go to their website and get the contact number to call and request a manual...usually at a fee...they ****. Next time, buy a Pride, Invacare, or whomever has the owners manuals online.
6helpful
Need mvp 4 hoveround manual
Hoveround is one of the few mfgr.s that don't post their owner manuals online; you need to call and request it at 1-800-542-7236.
32helpful
5answers
I need an instruction manual for a Hoveround MPV 4 Power Wheelcha
Call 1-800-771-6565 extention 5000. You will need the serial number of the chair and then they will get you a manual.
Top NRS Health & Beauty Experts
ADMIN Andrew
ADMIN Andrew
Harsal Patel
Harsal Patel
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
