Try to reset and pair it.To reset follow below instruction
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time
you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
As you already paired it with another phone try this,
Manual pairing
Press and hold answer end button approximately 5 sec and it will go to pairing mode.After this try to search with your phone/
Thank You
Thank You
Thank you so much...I've already tried that. The Jabra is back in the pairing mode, but the cell phone does not find any devices when searching. Do you have any other thoughts?
Thank you again!
Thank you...I've done that as well. I've taken out the battery of the cell phone to try to reset it, to no avail. I was able to successfully pair the Jabra with another phone, so it's not defective.
More thoughts? Thank you!
Your expert solved my issue after several tries! I'm very impressed and grateful!
