SOURCE: Please help, I can't turn on my HTC. What happened?
If you have a charged battery insert it and power the phone. If it hangs or whatever then (with the phone powered on, regardless of what's been displayed) keep on the keypad the two dashes ( - ) pressed and do a reset with the stylus. Do not leave the two buttons untill a black screen appears and ask you to press send (the green call button). Press it and you are done. If your phone doesn't have a hardware damage it should start. It will start from scratch again so you might be a bit patience.
SOURCE: HTC P3300 does not ON
Apologize for the delay in respose, was having a technical glitch at my end too. Well, if the phone is under one year manufacturer warranty , i would advice to take it in for repairs.
If the warranty is void , try hard reseting the phone ...caution before you do hard reset , it would delete all contacts and files that you saved on it after you got the phone.
Refer owners manual on how to reset the phone . If you donot have the same with , kindly lemme know
Thanks
proton
SOURCE: My HTC Touch suddenly turn off, and Is hard to start it again.
the solution to the problem is explained in detail here
http://mastermindinaction.blogspot.com/
SOURCE: htc p3300 problem
guys i have a question....did u all made upgrade rom from windows mobile 5 to wm 6?i did it...maby that is the problem
