You need to tighten retaining nut on the underside of sink. You will probably need someone to hold faucet steady while you tighten nut. Yom may be able to use channel lock pliersor adjustable wrench. They can be hard to get to as there is not much room. If you have to you can get a basin wrench at most hardware stores. Usually around $15.00. The head will turn from 90 degrees on one side to 90 degrees on other. To use turn head so that open end of jaws are pointing to your right if you are laying on your back under sink.Open jaws and put around retaing nut and turn counterclockwise. This will tighten jaws around nut and you should be able to tighten nut. If you need to you can apply penetrating fluid on threads and get it to tighten. Hope this helps. Thanks
