I turned my PVR on after charging, but all of a sudden it froze when it was starting up it said ''initalize'' in the corner just as normal, but it did not go to the menu like it should do, what should i do??? please help :(
Tje pvr-h140 basicall have 3 major components
1- 40 gb hard disk
2- battery pack similiar to the cordless phone battery packs
3- integrated panel with LCD and control buttons; usb port; power port; av in/out port.
when the unit hangs on initialize; this mean the hard disk is not responding. you can hit the recessed reset button and and power it back on. if the hard disk is OK this should clear up the issue.
if the hard disk is bad (crashed) then you need to replace the disk. Usually a fitjitsu 40GB notebook drive
also if the unit was dropped; constantly banged; etc then the cable to the hard disk to the integrated panel may be loose. The disk to cable is pinned and doesn't come loose but the other end of the cable is taped to the integrated panel and can come loose if the unit is not handled properly.
finally if the boot up files are corrupt; then you should be able to see it on the pc with the usb connection.
In this case you need to download and restore the files as discussed in the other solutions. Basically mustek has a website with all the drivers.
