SOURCE: BMW 325 TD STARTING FAULT
Replace the "glow plug" relay that is ussually situated next to the fuse box
SOURCE: BMW Keyless Entry not working
hi, to program the keys to the vehicle is quite simple
1) open the vehicle, sit inside and close the door
2) insert the key in the ignition and turn to position 1 so that just the air bag light illuminates
3) press and hold the unlock button on the key and remove the key from the ignition (do not release the unlock button)
4) while still holding the unlock button with the key removed press the lock button 3 times
5) release the unlock button on the remote and the door locks should lock and unlock if the proceedure has been carried out correctly
6) to program any other key(s) press and hold the unlock button on remote and again press the lock button 3 times but do not insert it into the ignition or turn the ignition on as done previous.
you may want to print these instructions and read them a few times before proceeding, if you muck up the process while programing keys, no harm will be done, you just have to start the process over. hope this is of some help, regards mark.
SOURCE: Would a crankshaft sensor fault cause my BMW to just cut out?
Short answer is yes it would. Not the only thing it could be but to answer your question, yes.
SOURCE: BMW X 3 Panoramic sun roof initialization.
I just had the same problem... the rear glass has 2 suports, which you will need to insert a long screw driver in it and force them back manually... It's a pain, but I can get you all the pictures to this procedure...
SOURCE: beeps while driving
Check your speed alarm in your computer. It maybe setup to alarm when going over that speed and it will only do it once during that trip if I remember correctly.
there are many software
available to unlock iphone 3gs and my friend unlocked it by remote unlocking..there
are many online providers who provide the service..one of my friend got
unlocked his iphone 3gs from Mobileunlocksolutions by remote unlock..and here is the
instructions
1. Wait for an email saying your phone has been activated or
remotely unlocked.
2. Install the latest version of iTunes.
3. Make sure your Apple iPhone phone software is updated to
the latest version
using the iTunes software.
4. Connect your Apple iPhone to iTunes with a NOT ACCEPTED
SIM card.
5. Wait until iTunes detects your Apple iPhone.
6. Disconnect your Apple iPhone and reconnect it after 10
seconds.
7. Your Apple iPhone is now unlocked.
and the important thing remote unlocking is available for some country and network providers only so if you are interested you can try from them before that see whether remote unlocking is available for your country and provider..
you can unlock your iphone..there are many software available to unlock iphone and my friend unlocked it by remote unlocking..there are many online providers who provide the service..one of my friend got unlocked his iphone from Simpleunlocking by remote unlock..and here is the instructions
1. Wait for an email saying your phone has been activated or remotely unlocked.
3. Make sure your Apple iPhone phone software is updated to the latest version
4. Connect your Apple iPhone to iTunes with a NOT ACCEPTED SIM card.
6. Disconnect your Apple iPhone and reconnect it after 10 seconds.
