The passcode is 0000 if you need the manual you can get it on the link below.
http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=147408&SEQ_NO=1
Good Luck
SOURCE: how do you connect samsung bluetooth headset
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
