I PLUG MY CHARGER INTO THE BLUETOOTH IT LIGHTS UP RED FOR ABOUT 3 SECONDS AND THEN IT TURNS OFF SO I THINK ITS CHARGED BUT WHEN I SWITCH IT ON I GET NO BLUE LIGHT TO INDICATE THAT IT'S ON PAIRING MODE ... I'VE NEVER PAIRED THIS BLUETOOTH WITH ANY OTHER DEVICE BEFORE.
Usually to pair a new device like that, there would be some trick to set it up. Im not familiar with your exact model, however ive had success with holding some buttons in.
Usually you would hold down the power button, or perhaps the volume up and down together, hold them down for a few secs and the light will go blue/red/blue/red to show its in pairing mode.
SOURCE: Motorola bluetooth H270 solid blue light after pairing
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Exactly the same problem . So , I returned the headset to motorola to receive another one . And the other one has the same problem again. I charged all the night ,pressed all buttons , tried to pair to a Samsung j600 but no detection.
the red light comes on when i plug in the charge lead for about 3 4 secs but then goes off i also tried using the usb lead from laptop same again
Hi!!! I´m in Brasil and have same problem.
The problem begins when i plug the charger.
Here in Brasil don´t solve it.
The operator phone substitue the phone but the new phone have problem too.
PASSWODE FOR R500
Two questions:
Do you have the bluetooth turned on (on the phone)?
What brand / model phone are you trying to pair it with?
Just got them opened the package and plugged into the wall, but doesn't seem to charge
I installes a blue tooth app. But after installing,I get a message that not bluetooth installed in your device.
I have a hipstreet equinox2___
O
