Question about Pelican Video Game Consoles & Games
I need a replacement cord for my pelican wireless adapter. What kind of cord do I need. amps volts, etc...?
    President:
  • 2,653 Answers
What model is the wireless adapter? Can you check it for a part number?
Posted on Nov 13, 2010
SOURCE:
How to connect a dryer
Hi Sheliah,
I'm an electrician and would like to help you. Assuming you're in the U.S. and this is an electric dryer (not gas), you will need to find a 240 (a.k.a. 250) volt / 30 amp circuit to connect it to for it to work. This would be connected to a double pole 30 amp circuit breaker in the electrical panel. There is no simple residential "adapter" to change voltage, current or number of wires - besides the old 3 wire grounding plug adapter in you grandmother's junk drawer. (What is a 50/250 volt dryer? - did you mean a 30A/250V?)
Your dryer should have a 4 wire cord with a 4 prong plug on the end - and it will need to be plugged into a matching outlet. The old electrical code allowed you to change the cord to match the outlet, but now it requires that both the cord and the outlet be a 4 wire type. The old 3 wire cord type is no longer permitted to be used when the dryer is moved or replaced. Of course, 3 wire cords are available everywhere and it is unlikely that anyone will turn you in for changing the dryer's 4 wire cord back to a 3 wire cord type (but I just wanted to tell they way it is supposed to be done). What you do - is your business.
If you have a gas (or LP) dryer, you probably only need a 120 volt / 15 or 20 amp outlet - they look like the standard types - but I think you'd have simply plugged it in and walked away if that were the case.
I hope this helped!
Apr 07, 2014 | Dryers
I don"t have a pelican receiver for my wireless gamepad,,what should i do??
buy the device you need or get the security of your reciever cracked by an expert giving you a multiple use of it like i got my reliance 3G modem security cracked running idea,tata docomo etc networks in my modem
Sep 23, 2013 | Pelican Xbox Eclipse II Wireless...
I have a Belkin F7D1301 v1...I need the power adpater... How much do es this cord cost. Where can it b purchased?
You need a 9 volt 1 amp power supply. Try e-bay using the model number. Should be $10-15.
Sep 20, 2011 | Belkin Basic Wireless Router
My tv Adapter is not working and i need another one . this what is at back of the ADAPTER AC ADAPTER SN 0530+___O___- MODEL ;AD0603S110/220-12 INPUT:100-240V~1.5A. 50-60HZ .OUTPUT:12VDC= 5A THAT...
The important information is the output voltage (12 volts DC) and current (5 amps). You need an adapter with those ratings and a plug with the proper size and polarity to fit the TV. If necessary, you can salvage the output cord from the bad adapter and splice it onto a replacement if you can't find one with the right plug. You need to be careful to get the polarity right or you can damage the TV. Most sets have the center pin positive, but you want to check to be sure. The set usually is marked with the information, and it may also be on the old adapter.
You may be able to find an exact replacement adapter by searching for your specific TV brand and model number and "replacement power adapter". Many adapters are available through eBay sellers. Otherwise just look for a 12-volt 5-amp adapter and change the output cord as described if necessary.
Good luck and thanks for using Fixya!
May 16, 2011 | Goodmans 289NS 14" TV
I don't have either cord to charge or use the light. What kind of charger cord and what kind of other cord (12 volts ?) do I need to use the light?
Black and Decker's website has downloadable OEM manual which gives part numbers to replace power adapter, also sold at Radio Shacks or RV places like Boat and RV which can be Googled. Best Buy also sells AC/DC relacement multi voltage universal adapters which are about $12.00 - $20.00. Hope this helps ! Matthew
Jan 10, 2011 | Vector 1 Million Rechargeable Spotlight
I dont have a power cord for a monitor a friend gave me....what kind do i need? Model# 780 Product# E17Tr
99% of monitors use a "standard" PC power-cable, exactly the same as is between your computer's power-supply and the wall outlet.
Go to any "Thrift Store", and don't pay more than $1 for a power-cable.
Apr 05, 2010 | E-Machines eMachines Monitor E15T4
Looking for website to download pelican installation cd
download pelican installation cd. (0.16 seconds) Sponsored Links
  1. Protective Casestbr:res?m=stwsg&id=gray_shieldCases from HPRC & Pelican
    Great range. Great prices.
    www.prospectors.com.au
  2. Software Download Websitetbr:res?m=stwsg&id=gray_shield
  3. Downloadtbr:res?m=stwsg&id=red_shieldTop Five Storage Tips for 2008.
    Download, Free Tips & Trends
    searchStorageChannel.TechTarget.com
(function(){ var a=document.styleSheets[0],b=a.rules,c=document.getElementById("mbEnd"),d,e=0;a.addRule(".s","width:auto");d=b[b.length-1].style;function f(){d.width=document.body.clientWidth-(c?c.offsetWidth:0)100){f();e=g}});f(); })() (new Image()).src="http://www.google.co.in/verify/EAAAACiKRbvi6OLBwvsQ6o8G_so.gif"; eaaaacikrbvi6olbwvsq6o8g_so.gif
Dec 04, 2008 | Network Associates Sniffer Pro ATM pod...
Pelican wireless gaming adapter
I have the same thing. The device is a P.O.S
Oct 23, 2008 | Video Game Consoles & Games
My Pelican PL-3669 Wireless Gaming Adaptor and Mac.... how to connect?
My pelican wireless network adapter(PC) stopped working one day. Only 3 of the 4 lights light up and I can't connect to xbox live. I've reinstalled and reset and reinstalled. Nothing works!
Mar 29, 2008 | Video Game Consoles & Games
Video Game Consoles & Games Logo
186 people viewed this question
Top Pelican Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you a Pelican Video Game Console and Game Expert? Answer questions, earn points and help others
