SOURCE: Kenwood dishwasher kdw243a
kdw243a code E3 what doesthis mean. ??? pleae.. adres Poland,,,,,, e_mail [email protected]
SOURCE: error code e4 on kenwood kdw12st3a dishwasher too much inlet wate
HI there,
I have had the same problem as most of you. I seem to have fixed it by
1. Bail out all the water from the inside
2. Remove the filter and 2 x mesh pieces.
3. Continue to bail out the water from the filter well.
4. You will probably find pieces of food or fat/debris in the bottom of the well. Remove these.
5. Tilt back the dishwasher at 45 degrees for 30 mins or so to drain and dry the flood sensor.
6. Boil a kettle and pour it down the well. Immediately put the dish washer on a eco wash (no tablets or anything) with half load (ie half water) and this will ease the water pump.
7. Let the dishwasher run its cycle.
8. Clean the filter again and the filter well.
It sounds quite long winded but with a £250 item you need to take care of it. Make sure you rinse most plates before loading in the future.
Hope this helps!!!
Good Luck!!!
neo
SOURCE: kenwood dishwasher kdw12st3a user guide
GO TO PARTMASTER http://www.partmaster.co.uk/cgi-bin/home.pl
SCROLL DOWN TO BOTTOM LEFT AND USE INSTRUCTION MANUAL DOWNLOAD
AND ITS FREE.
SOURCE: kenwood dishwasher flashing E3 towards end of
As far as I know, E3 on a Kenwood is related to the temperature sensor, when you open it, are the dishes warm?
Testimonial: "thanks for that did not think of the temp and yes dishes sometimes come out cold "
SOURCE: kenwood KDW12ST3A
E1 indicated long filling time. Perhaps the inlet filter has clogged. Check the inlet pipe and tap(faucet in usa).
