The foam is a product called neoprene tubing and can be found at specialist rubber product suppliers. Google a local supplier. Changing the grab bar rubber is easy just use hot soapy water but the handle bar is a problem as the foam is fitted before assembly and it would require disassembly to replace. This is not easy as the handle is riveted on and has internal parts to operate the handle locks. You can buy a special glue for repairing wetsuits to fix the split and stop it opening up further.
Repairyabuggy sell these grips,we had our quinny buzz grips replaced and they are excellant,better than cheap foam from the bike shops call jeff on 07886531199
