Hi i'm looking for that solution too but found by myself you just need to remove the 2 front speaker grille just pull off and after remove the eight rubber that retained the grille the screws is under these rubbers and after gently pry the front cabinet
Don't forget the tiny screw in the center of the top behind the display panel. You have to pry off the clear plastic bezel faceplate to get to it.
Forget about the four easily accessible silver screws in the bottom. They are only to mount the hefty transformer inside, and won't help gain access inside the unit.
I need details for a physical teardown
how do you pull off front speeker grills
