SOURCE: i need repair help. no schematics
It sounds like the power supply (inside the amp) isn't producing voltage. This is generally due to blown power supply FETs but can be caused by broken connections. I'm assuming that you've checked the remote and B+ and they're at least 12v at the amp.
SOURCE: my amp wont go past protect mode
I had the same problem. be sure to change all transistors cause once one goes the rest useally goes right along with it... replaceing one or two transistors will not do the trick, cause once you power up again the rest of them will go, & you will have to repeat the prosses
SOURCE: Not sure whats wrong with my LANZAR MXA242 AMPLIFER. Please help!
did you check the fuses on the side of the amp? put voltage meter on b+ should read 13v, take it to service center to have checked out, may have some prblems inside
SOURCE: do you have a manual on the lanzar 210 how to
LOOK AT WHERE THE SPEAKER YOU WILL SEE BRIDGE DIAGRAM
SOURCE: audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
