Its a very common problem. Generally peoples push reset button
10-15 sec for reset that it not good enough to return your router to
factory setting. So old the reset button this time at least 30-40
second. And try now for a new setting.
I hope, it helps.
Feel free to get instant online Belkin router support at http://vtechsquad.ca/belkin-router-support/ to fix Belkin router/wireless router issues.
The router can be set to factory default by performing either of these two steps: Resetting the Router Using the Reset Button NOTE: Pressing the Reset button
on the back of the router for 30 seconds will reset your router to its
factory default settings. All of the settings of the router will then
be erased and the router's IP address will become 192.168.1.1. To perform a hardware reset on your Linksys router, follow these steps:
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
Figure 2: Location of the Reset button on a Linksys WRT54GX rCannot remember log in info - 4030-024.png
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 4:
Related Articles: Accessing the Router's Web-Based Setup Page
Resetting the Router Using the Web-Based Setup Page
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
NOTE: The image may vary depending on the model number of the Linksys device.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then clicCannot remember log in info - kb4008-004_en.pngefaults.
Step 3:
ClCannot remember log in info - kb4008-005_en.png Factory Defaults and select Yes.
Click OK.
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
