the Konica Minolta Bizhub C350 is by nature a slow printing machine the standard memory that the machine comes with is only 256mb and it can only be upgraded to 512mb . but there are some things you can do to help speed it up a little. touch the utility/counter button touch admin setting on the touchscreen enter the admin password touch system setting touch output setting touch print/fax output settings touch print select between page print and batch print=select page print exit all the way out of admin mode then reboot the copier tests have shown that this changed a print job from taking a little over 2 minutes to taking about 9 seconds to start printing keep in mind this is definately not the fastest printing machine on the market hope this helps thanks for using fixya
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start. Good luck!
You have to have a fiery unit (external controler) to use the C350 With a Mac because the c350 dosnt come with appletalk in the software. IC-401 Is the model number of the controller you will need to connect the c350 to any kind of mac for printing / scanning.
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
I guess you mean the c350 is not printing while Windows said the job has been sent?
If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g.
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
