Frigidaire ATF6000ES Front Load Washer Logo
Posted on Nov 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Anonymous
Level 3:
President:
  • Master 1,554 Answers
  • Posted on Nov 13, 2010
Anonymous
Master
Level 3:
President:
Answers
1554
Questions
0
Helped
611974
Points
4917
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
How to reset an error code e43 on a frigidaire affinity front load washer
Hii Michael, Search online for "error code e43 reset". You should get a hit on justanswer.com. Follow that link, it looks promising.
What are the cubic feet for the affinity atf6000fs1
Hello Friend, this is Z. That's a great question!
I show that your Frigidaire Affinity washer (ATF6000FS1) has a total capacity of 3.5 cubic foot. Hope this helps! If there is anything else that I can help you with, please feel free to reconnect.
Door won't unlock on my ATF6000FS1
Hello Friend, this is Z. Thank you for allowing me to assist you!
I see that your Frigidaire washer (ATF6000FS1) door will not unlock. Sometimes, resetting power to your washer for about to 10 minutes does the trick. Once you turn on your washer, select a normal cycle and verify if the door will unlock. If not, your washer may possibly have a faulty door lock assembly, or a communication problem with the control board. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
1helpful
Atf6000fs1
Hello partridgemcl - From what you are describing the strike is the part that engages the door switch. It is mounted to the door. The part number is 134456600, MSRP: $6.12. The new seal that you are referring to is the bellows, boot. The part number is 134740900, MSPR: $125.37. You may purchase the part(s) directly from the manufacturer or through a part distributor in your area.
My frigidaire affinity front load washer ATF6000FS1 wont fill with water
Hello hitman43 - Are the house valves turn on fully? Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Contact a professional to move forward accurately.
Need to print manual on how to use my washer Affinity model.
This is the first one I found, check your complete model number and make sure it matches, if not the others are available in the Frigidaire website.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134850600een.pdf
Let me know if this helps,
Thank you
1helpful
Washer won't start and DR displays
means door is open. If door is infact closed, i would say you have a faulty door switch. Replace and test, part number is 131763202
Will not spin during spin portion of cycles. it rotates slowly cw and ccw but no fast spin
It's either a bad door switch, or motor control board. Definitely easier and cheaper to try changint he door switch first, as it fails much more often. Part number is 131763202
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
