Question about Intel Motherboard
Replacing bad motherboard, but now sure where some of the connectors go
I am in the process of replacing my ms7207 in my eMachines t6420 and I am having some trouble figuring out how to rehook the front connectors. It is a series of 3 connectors with different colored wires; one with red and white; one with black and white; one with white and green.
  • Intel Master
  • 2,075 Answers
They all have some letters on them (as well as on mobo) indicating where to connect
Posted on Feb 02, 2018
SOURCE:
SOURCE: emachine T2742 MB D845EPI/D845GVSR
The diagram for that 9 pin J9G1 is alongside the CMOS battery.
Posted on Dec 26, 2007
  • 243 Answers
SOURCE: MOTHERBOARD WIRING
Instructions should be in the manual found here
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=302
They sound like they are for your from usb posts on case...but thats just a gues :)
Hope that sorts it for you?
Posted on Dec 30, 2007
map9966
  • 2351 Answers
SOURCE: wiring hookup instructions for ecs 945 gct -m mATX motherboard
Hi joe, if you're question refers to ECS 945GCT-M motherboard, than goto page 12 in the manual. You'll see this
77d37bb.jpg Please read all of pg.12.
It's my guess you bought this board from powerspec. For now forget the two red wires & just hook up the case's wires for all LED's & on/off. Everything should be just fine.
Good Luck!
Mike
Posted on Jul 02, 2008
SOURCE: Repalced bad MS 7207 mobo with new one
Go here to see where the wires go...good luck!
http://support.gateway.com/s/MOTHERBD/MSI/105551/105551mvr13.shtml
Posted on Aug 13, 2008
ice48507
  • 28 Answers
SOURCE: Emachine T3828 power switch connection to motherboard
The "Ultra Helpful Instructions" that Emachines provide (here: http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf) state that when replacing the system board, "18. Attach all cables to new system board", but fails to say where that would be for each cable.
The site below says it's a genuine Intel board in there, so, congrats on that. http://www.e4allupgraders.info/dir1/motherboards/socket478/D845GVSR.shtml
And with that, the link to the manual:
ftp://download.intel.com/support/motherboards/desktop/D845GVSR/SR_English.pdf
You're looking for the info on page 32, I believe.
See if that fixes it up. If not, post back.
Posted on Jan 03, 2009
Emachine total black , this are on fan
LED lights are on? Fans spin? I suggest you have a bad Power Supply.
1) eMachines are noted to have low quality Power Supply's.
Saves eMachines money so they can sell budget computers.
2) A bad Power Supply is one of the leading causes of computer failure. I have, (Had actually), a shop half full of computers with this 'ailment'.
Some caused by the owners never cleaned out the inside of their computer, nor the inside of the Power Supply, with a can of compressed air for computers on a regular basis as needed.
3 to 5 years without cleaning the inside of their computer.
Mice could have made nests inside easily, with the 'Gunk' that was there. A bald eagle could have too. Rant off.
Others, caused by the computer manufacturer used a low quality Power Supply.
Low quality components used inside.
One of the major components that fails, is caused by a particular Electrolytic Capacitor that is used.
http://en.wikipedia.org/wiki/Capacitor_plague
3) Power Supply's used in PC's are a type of SMPS.
(Personal Computer. Statement holds true no matter what type of personal computer it is)
[ SMPS = Switched-Mode Power Supply
PSU = Power Supply Unit
All terms relate to a Power Supply used in a PC ]
A bad Power Supply will have a weak voltage power rail.
There are three major power rails used in the ATX form factor Power Supply, for an eMachines T6420 desktop computer.
A) The 3.3 Volt power rail (DC)
B) The 5 Volt power rail (DC)
C) The 12 Volt power rail (DC)
(Two D cell flashlight batteries produce 3 Volts DC)
A Power Supply with a weak voltage power rail, may have enough power to light LED lights, and spin fans, (or spin a few times, ans stop), but won't have enough power to turn the Processor on.
1) ALL the LED lights combined use less than 1 Watt of power
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts.
Depends on what Processor it is.
eMachines T6420?
Uses an AMD Athlon 64 3400+, processor.
(Socket 939)
[The motherboard used is an MSI ms-7207
Also known as K8NGM2-L ]
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6420
This Processor can use Up To 89 Watts.
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_processors#.22Newcastle.22_.28CG.2C_130_nm.29
No Processor running, No computer.
No computer = No Video Signal
Suggest using a KNOWN to be Good, Compatible power supply, for a test unit, if available.
Should be the ATX form factor.
Approximately 6 inches Long, (15.24cm), 6 inches Wide, (15.24cm), and 3-1/2 inches Tall. (8.89cm)
250 Watts.
Correct amount of power cables, and the correct type.
Sep 20, 2010 | E-Machines T6420 PC Desktop
The monitor will not get a connection. I need to know where the video card is located.
This is eMachines Support, T6420 desktop computer>Specifications, and downloads page for the User Guides,
The eMachines T6420 does not come with a graphics card from the factory.
It comes with Integrated Graphics.
Integrated Graphics is also known as OnBoard Graphics.
On the motherBoard
The GPU is soldered to the motherboard.
(Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
OR,
someone has installed a graphics card, into the PCI Express x16 slot on the motherboard.
You can determine real easily if your computer is using Integrated Graphics, or a graphics card.
If it is using Integrated Graphics, the monitor will be plugged into the I/O area, on the back of the computer, and into a VGA port,
http://en.wikipedia.org/wiki/VGA_connector
(I/O area;
I/O = Input/Output
The I/O area, is the area that has the rectangular metal shield, and Input/Output devices are plugged into this area.
Devices such as a Keyboard, Mouse, Printer, and so on )
HOWEVER, with the motherboard used in an eMachines T6420, the I/O area could also have a white DVI port.
http://en.wikipedia.org/wiki/Digital_Visual_Interface
This was an option offered. The DVI port still connects to the Integrated Graphics on the motherboard.
The eMachines T6420 uses an MSI MS-7207 motherboard.
(Micro Star International, Inc.)
http://www.tigerdirect.com/applications/searchtools/item-detailsInactive.asp?EdpNo=2665522
The above link is to,
1) Show the motherboard
2) Provides a link to the Motherboard Manual
Looking at the photo of the motherboard, you will see two long White slots.
Above these two slots you will see a longer White slot.
The bottom two white slots are PCI expansion slots.
The top longer slot is a PCI Express x16, expansion slot.
This is where a PCI Express graphics card would go.
I would like you to scroll to the bottom of the page, to the Product Resources heading.
Under it is a link to the Motherboard Manual, for the MSI MS-7207 motherboard.
Left-click on the blue - MSI K8NGM2 Series Manual.
You will be looking at a blank white page, as the PDF file downloads in the background.
Took 34 seconds with a medium speed DSL connection, for me to download it.
NOW,
No Signal on the monitor, means the monitor is Not receiving a video signal.
1) Check the monitor cable if it is removable. Use it on another working computer to insure it is good.
2) If the monitor cable proves to be good, the next area to check would be the graphics.
If the computer is using Integrated Graphics, and no one has installed a graphics card, the test would be to install a graphics card, and plug the monitor into it.
Computer off, unplugged from power, Anti-Static precautions are observed before reaching inside the computer, and handling the graphics card.
I don't think the problem is the graphics. Could be wrong, but we'll see.
Let's carry the diagnosis past the graphics for now.
I think the problem could be due to a bad Power Supply.
Weak Voltage power rail.
Enough power to light lights, and spin fans (Perhaps), but not enough to turn the Processor on.
(Fans may be spinning, or may just spin a few times, and stop)
1) ALL the lights use Less than 1 Watt of power
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Continued in an additional Comment.
Jun 12, 2010 | E-Machines T6420 PC Desktop
Emachine t6420 suddenly shutting down after about 15 min. - 1/2hr. Power button on HD blinking on and off slowly. Can get it to start up again by taking out the electric plug and waiting a min. and...
Check on the processor installed inside the computer's motherboard, it might be loosen and make sure it is properly locked. Also check for the fan. Make sure the cpu is properly ventilated to avoid overheating that might cause the shutdown.
Sep 28, 2009 | E-Machines T6420 PC Desktop
I am in need of network driver for the Emachines t6420, please?
The motherboard in the machine is an MS-7207
The chipset drivers are nForce 430/410
You can download the chipset drivers from nVidia here >>>>>>>>>
http://www.nvidia.com/object/nforce_nf4_winxp32_8.26_11.09.html
Don't worry, the network (LAN) driver is included in the package.
Regards.
Sep 03, 2009 | E-Machines T6420 PC Desktop
Emachine T6420 motherboard
http://www.pcfactoryoutlet.com/Moreinfo.asp?StoreID=8&Product_Id=69281 that should be where you can find it! Let me know if I can help you with anything else! thanks!
Jun 08, 2009 | E-Machines eMachines Desktop PC
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Need emachine t6420 network driver
go to a coputer store and tell them what you need then it goes right in to the back it sould come with drictions
Jan 20, 2009 | E-Machines T6420 PC Desktop
I have a emachine T6420
ohk i also have an emachine make sure you have the moniter hooked up all the way i have had the same problem
Dec 31, 2008 | E-Machines T6420 PC Desktop
Failed processor upgrade
YOOUR MOTHERBOARD HAS A SOCKET # YOU NEED TO GET AN AMD X2 CPU THAT MATCHES SOCKET#.RICHARDM69
Dec 04, 2008 | E-Machines T6420 PC Desktop
T6420 bad on board video red is out Does it make sence to put a new video board in this machine
If you want to continue using the machine it does. If not time to get a new one.
Apr 20, 2008 | E-Machines eMachines Desktop PC
Intel Motherboard Logo
69 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
