The television turns off by itself. Sometimes just the picture disappears but you still have the audio. The error code is 5 flashes repeated. When the power button is pushed to on, the screen turns blue,there are ghost images on the screen for only a few seconds then the unit shuts off. Any help will be very much appreciated.
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Model number for tis problem is a Sony KP-51WS510
Today, the tv is flashing an error code 8. It was only flashing 5 times
last night. Is the Blue CRT test still needed since the error code has
changed? I plan to work on the tv tonight after work. Thanks
The red color on my KP-51ws510 looks like its drooping at the top left, and both bottom corners. The top right corner and center are perfect. The red LED is blinking 5 times every few seconds. What can I do?
