Few days back i was just surfing n found som1 having a same problem.the person solved it n has given up his solution comment n suggestions on how to rectify this problem on the direct link i m giving u below.hope it helps u:
http://www.corporaterefugee.com/pc_on_mac.html
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
The 3D Embroidery System is not designed to operate on Windows Vista. This is also true for earlier embroidery software. The compatible operating systems are stated on the product boxes. Therefore, it is not guaranteed that the 3D Embroidery System, or previous software, will function correctly on Windows Vista.
See link
http://www.secretsof.com/wp/?p=193
Yes this is a known issue with Vista. First question, dya guys have admin access on that PC ?Did you ever try using a dift platform such us XP? If yes and that didnt help.. lets move on . Quickest and best option to deal with this is try to uninstall everything about that software restart your PC and try to reinstall it back without any programs running on the background including firewall and anti-virus etc. If that doesnt help try a dift USB port and STILL wont work try installing it on SAFE MODE and check what happens.
If everything fails, try to use XP and inthat way youl isolate clearly what the problem is.
Easy huh? thats Vista. ...
Just leme know if you may have additional questions re my post
Cheers
Found this possible solution elsewhere on the net:
If you have upgraded your computer to Microsoft Vista operating
system or are using Vista anyways, and are experiencing problems with your 3D software, you should
first upgrade your dongle driver:
Hope that helps!!
Try this link for more useful info:
http://www.heirloomsandcomforts.net/supp...
PS - If you found my solution helpful in any way or led you to a fix, kindly take a moment to "Accept" it.
Thanks in advance,
IrishDruid.
This link will provide you all the software you require for your Husqvarna:
http://www.husqvarnaviking.com/global/85...
You can even download the latest 4D Software, and find links to FAQ's for the 3D version, and a download link for D Software as well..
Hope that helps, and Good Luck!
First go to the control panel and then to add/remove programs.
Next find the software and remove/uninstall it
next reboot the computer
next re-install the software
Since you got the dongle working after the software was already installed, it should work better now with a fresh install.
Dave
You need to reinstall the software this time like a clean install that should fix the problem..
Good luck..........
Try using a different software like this check the link:
http://www.sewgoodsoftware.com/anchor.ht...
http://www.fullreleases.com/NewMembers/p...
Hope that helps........
Check this one also:
http://rbytes.net/software/stitch-shop-r...
I think this one will enlighten you:
However, it is possible to install 3D Embroidery System software on Windows Vista. To get your dongle working, after installing your 3D Embroidery System software, see FAQ #H013.
There are no other adjustments to the 3D Embroidery System in respect of Windows? Vista. The operation of the Designer SE, Designer I and Parallel Reader/Writer unit should not be affected, apart from driver installation. You may need to answer some security questions in Windows Vista while installing the hardware drivers, as the drivers were designed for previous operating systems.
A workaround is necessary when using the USB Reader/Writer and d-Card Reader/Writer. Each time you use either the USB Reader/Writer or d-Card Reader/Writer to read a card, write a card or send an embroidery with Send 1 or Send 2, you must disconnect and reconnect the unit before using it again to read, write or send.
Note that in due course, a new solution will be available for using the USB Reader/Writer and d-Card Reader/Writer with Windows Vista. If you do not qualify for free upgrades, there may be a handling fee for providing the CD containing the solution as it will not be part of the 3D Embroidery System.
FAQ#H013 Error “No dongle attached. Cannot open program” when starting my 3D software on Windows Vista, even though my dongle is inserted.
After you have installed the 3D Embroidery System software on a Windows Vista computer, download and save the 3D Embroidery Vista Dongle Update. After saving the file on your computer, double-click the file to install the dongle update.
Note: If the following User Account Control message appears when installing the update: “An unidentified program wants access to your computer”, click the ‘Allow’ option to continue.
Just inform me if that solve your concern........
Check this link for the update http://www.husqvarnaviking.com/US/2821_3...
You can update your embroidery software but provided that you have register your software with Husqvarna then you can go to this link for the update http://www.husqvarnavikingsoftware.com/r...
Check device manager for dongle drivers and see if there is any conflict with drivers..if you see a yellow exclamation mark than correct drivers are not installed..uninstall the driver for dongle and use http://windowsupdate.microsoft.com/ and see if there is any drivers for dongle.......let me know if this works
search for the dongle drivers at google.com if not let me know which dongle you are using so that i can find drivers and software for it,or try windows update if it finds the latest drivers for the dongle ....if yes well and good.
You might be using wrong software for your dongle ...it needs proper software for interaction with operating system....
Most likely the dongle is not compatible with you computer. What kind of computer is it. What operating system are you running.
Thank you,
Nate
H013 Error "No dongle attached. Cannot open program" when starting my 3D software on Windows® Vista, even though my dongle is inserted.
After you have installed the 3D Embroidery System software on a Windows® Vista computer, download and save the 3D Embroidery Vista Dongle Update http://www.emnetsoftware.com/downloads/u...]. After saving the file on your computer, double-click the file to install the dongle update.
Note: If the following User Account Control message appears when installing the update: "An unidentified program wants access to your computer", click the 'Allow' option to continue
If you have vista you need to do this as the dongle was not originally designed for it.
Thanks,
Lee
1st try another usb port
2nd uninstall the software and plug the device in only after you have reinstalled the software and you are asked to plug it in. If it doesn't ask then install the software first and try again.
You can also right click on my computer and select manage.
then on the left side of the window select device manager, unplug and plug back the usb dongle and see if any devices appear or disappear also note any yellow ! marks. you may have to press the scan for new hardware button or right click on the window to scan for hardware changes.
Try to install the software from the download as its latest version its will prompt you to remove the old version on your computer and follow onscreen instruction you be able to install the software...........
Please use this link to register and you will get the support from the company itself:
http://ecom.husqvarnaviking.com/vsm_onli...
Try to clean the usb port with a contact cleaner or a lighter fluid, and also your output from your unit,with the use of old toothbrush,brushing each usb port and or change with a new usb cord.after all of this try plug the device and click its goin to run.
It is not the computer that is not recognizing the dongle it is the software. I cannot even open the software now, it is stating that no HASP security file found.
downloading an update for the Vista things sounds great, except the website that was given will not open or require "Employees" to sign in to download the update. Any other suggestions as to where to go to get a Vista dongle update?
Anyone know where to go to download the latest version of 3dEmbroidery Software?
Hi rdea64pny, you most likely have a new PC with windows 10 by now. Like me I have and the expensive 3D embroidery software and windows 10 would not recognize the dongle. I've searched the internet for days now, and finely found the driver that will work. I'm posting the link for the driver, it's GREAT! you not only get the driver but also answers to other issues that you may run into installing it. I have no issues, once I installed the driver IT WORKED. I hope this will help you, please pass it along to others who may need the updated driver for windows 10 since Husqvarna no longer supports the older software. I'm thrilled that I have my 3D embroidery software working again. And want to share this information to everyone who can use it.
You may need to copy and paste into your browser.
http://www.cimexcorp.com/hasp_fix.htm#:~...
