HTC HD2 Smartphone Logo
Posted on Sep 10, 2017
When starting up my htc hd2 cellphone i cant open settings, or any applicaions... and this message pops out... " cannot open 'htcsettingentry' a critical component is either missing or cannot start bacause program memory is unavailable. tap start, settings, system tab, task manager. " how can i do thid instrudion if i cant enter settings? what should i do?
5 Related Answers
Anonymous
  • 264 Answers
  • Posted on May 31, 2010
SOURCE: "Memory is full. Please delete some messages."
Initially go to Internet explorer
select menu
select tools
select options
choose the memory tab
delete all cookies and temp files
If there are more messages in send items delete that too.
Hope this helps you
Anonymous
  • Posted on Jul 23, 2010
SOURCE: How to decrypt .menc files on HTC HD2
I have the same issue and it sucks!
WIMAGE09
WIRELESS IMAGE
  • 282 Answers
  • Posted on Oct 29, 2010
SOURCE: my htc hd2 wont start up keeps turning itself off
http://www.hardreset.eu/htc_touch_hd_hard_reset_soft_reset_en.html
try to perform a hard reset and see if that will fix your problem. But before you do ill have tell you will lose all your information on that phone once its hard reset.
Hope this will help you...thanks
Anonymous
  • 783 Answers
  • Posted on Jan 10, 2011
SOURCE: HTC HD2 not "booting up" I have an HTC HD2
take it to your service provider they will fix your problem on the spot usually or order you a new one free of charge. -Derek
Mathue
  • 61 Answers
  • Posted on Feb 20, 2011
SOURCE: M HTC surround phone wont
try taking out the battery waiting an hour and then put it back in... Cell phones are like mini-computers and will crash once in awhile
When sent sms appear invailed recipent immediateluy. what should i do?
The best solution I can recommend is to reset your cellphone into original factory setting. It happens most of the time due to regular use.. like downloading and uploading different contents from your cellphone.
My HTC HD2 wont start, showed error with "cprog.exe" I'v tryed soft start, tokk out batary, but now I onslu come to HTC picture when starting up,, no buttons is function..
I'm sorry, but I think you will need to contact T-Mobile for support. Call them from another phone at 1-800-T-Mobile.
If you don't care much about the info on the phone, then do a hard reset to factory defaults.
http://www.hard-reset.com/htc-hd2-leo-hard-reset.html
CAUTION - DOING A HARD RESET, YOU WILL LOSE EVERYTHING ON YOUR PHONE. REMOVE THE MEMORY CARD BEFORE DOING A HARD RESET.
Good Luck,
Mark
I have an HTC HD2. I believe I have so many old txt messages that they are now stopping the HTC from working ! I can just about get into "All Messages" but I can't get "Deleted Items"...
Synchronize the phone to your PC. Remove the memory card and do a factory default.
Good Luck,
Mark
2helpful
How do i get a manual configuration for GPRS setting for my htc hd2 phone?
sir please call to the related simcard customer care and say the cellphone model number.and the phonenumber then they will send the gprs settings to your cellphone save the settings and switch off your cellphone and again switch on.then connect the data cable from phone to the computer for connecting the internet...........
I got may htc hd2 in september 2010 and never got a stable funtioning. In general it My htc hd2 phone go to restarting many time and stay in stick together for a long long time. After 20 minutes off it...
Hello.
You may have an overheating problem.
First, remove the back of your phone and remove and reinsert the battery.
If still a problem, return and replace your phone, since the phone is still under warranty and you have not had success with this phone.
Hope this helps.
15helpful
2answers
How to format htc hd2?
hii...
steps
1. Start menu.
2. Setting >System >Default Setting
3. Enter the 1234
4. ok
3helpful
5answers
CANT PHONE ANYONE
It was possibly not unlocked properly. When you bought it, what carrier was it locked to? You can buy an unlock code on ebay for about $10:
http://shop.ebay.com/i.html?_nkw=HTC+HD2+unlock+code&_sacat=0&_dmpt=PDA_Accessories&_odkw=Motorola+Motozine+screen&_osacat=0&bkBtn=&_trksid=p3286.m270.l1313
2answers
System error of memory card
I had a 3650 and I get this error often. What I do is visit the celfone shops and have the operating system reinstalled. There's not much you can do on your part as every button you press leads to the system application error.
May 29, 2006 • Nokia 3650
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
