Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method
You can only use it in the 2.4 ghz mode or the 5 ghz mode:
1. Log in to the Router by going to http://www.routerlogin.net or http://www.routerlogin.com
and entering the default user name admin and default password password, or using whatever
LAN address and password you have set up.
2. Select Wireless Settings under Setup in the main menu to display the Wireless Settings
screen.
3. Select the region in which the wireless interface will operate.
4. Set up the 2.4 GHz wireless network:
a. Enter the SSID name. The default is NETGEAR.
b. Select the operating channel for the wireless mode. The default is Auto. When Auto is
selected, the router finds the best operating channel available.
If you notice interference from nearby devices, you can select a different channel.
Channels 1, 6, and 11 will not interfere with each other.
c. Leave the wireless mode set to the default setting of Up to 145Mbps for 2.4GHz.
5. Select security options for the 2.4GHz wireless network.
The wireless Security Options are set to None by default. NETGEAR strongly recommends
that you use wireless security. You can select a different Security Option and a different
passphrase for each wireless network. For the highest performance of the 2.4GHz wireless
network and the most secure encryption, NETGEAR recommends that you use WPA2-PSK as
your security option.
6. Set up the 5GHz wireless network:
a. Enter the SSID name. The default is NETGEAR-5G.
b. Select the operating channel for the wireless mode. The default channel is 36. If there is an
Auto option in the channel list and you select it, the router will find the best operating
channel available.
c. Leave the wireless mode set to the default setting of Up to 300Mbps for 5GHz.
7. Select security options for the 5 GHz wireless network.
passphrase for each wireless network. For the highest performance of the 5 GHz wireless
network and the most secure encryption, NETGEAR recommends that you use WPA2-PSK asyour security option.
8. Click Apply to save your changes.
please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
