There are 3 visible screws there in the handle and one not so visible.
start by removing the 3 visible screws.
Take a flat screwdriver and pry off the colored portion of the handle that would contain the switch.
There is one more screw in the handle just in front of the switch, remove that one.
This is where it gets tricky.
under the handle between the handle and the hose, is a little square shaped pry area that is locked. Use the same flat screwdriver to get at that and release it. The rest of the handle should come apart pretty easy now.
Good luck.
Mark
