Konica Minolta magicolor 2430 DL Laser Printer Logo
Posted on Nov 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
Sudeep Chatterjee
Level 3:
  • Konica Minolta Master 3,267 Answers
  • Posted on Nov 11, 2010
Sudeep Chatterjee
Level 3:
Answers
3267
Questions
10
Helped
1158346
Points
10260
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Konica minolta 2530 dl Replaced black cartridge now says others not installed and "cannot rotate cartridges"
Clean toner chip reader, remove OPC drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it.
1helpful
Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
9helpful
2answers
Error 2408
2helpful
2answers
Toner not installed problem Err: Line 2408
i have the same problem. my printer says all of the toner cartridges are not installed. i have taken each one out and returned them, and have rebooted the printer multiple times. nothing helps.
Konica Minolta 2430 DL Xtoner not installed
Check the toner contacts in the printer, you may find one either dirty , bent or broken.
Konica minolta magiccolor 2430 dl
Under Quality Tab you have the option for B/W printing.
5answers
Error code
toner chip is gone replace cartrige
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
