There is no need to worry a lot what you can do is that, just open the toner access door located at the front of the printer and then you can scroll down the list of cartridges until you find the one which is giving you the message of Replacing toner.
Then press the button "1" to reset the display toner settings. If still you find any of the difficulties then we have a best place available which can actually sort out your issue and they are Micro Toner Supplies and their official website is where you can find a lot of things is https://www.microtonersupplies.com.au/toner/xerox-toner-cartridges
Basically these guys(Xerox Toner Cartridges) are famous for supplying cartridges at a specific cost and to your mentioned area but in this site there is a contact option available where you can contact them and can solve you issue. Hope this may work to you and if still you find any difficult even after accessing the prescribed website then there are many other websites where you can find better solutions.
I knew it needed to be reset to recognize the new toner. Glad you found the info in the electronic menu. Thanks for using Fixya. If my suggestion was helpful could you please rate it for Fixya. Thanks
I fail to see why you are covering up the toner sensor led's when you have a new cartridge fitted? Also if you are using a recycled toner from a very well known uk shop that refills toners and ink then you may well have broken the drive gear that stirs the toner. i have seen this six times and their toners do this. It could well be one of the pitfuls of recycled toners.
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
When the Toner Life End LED flips on, requires you to replace the cartridge,
even when there's still toner left in the cartridge. The machine
detects end of life by shining a light through from one side to the
other. To circumvent the detection mechanism, remove the cartridge and put
a piece of masking tape over or jam a little bit of paper into the clear opening/circle on the right side
of the toner cartridge, and then pop the cartridge back in. Eventually,
you'll start seeing streaks, and then you'll know that the cartridge is
truly empty.
