Look around for a subwoofer which has speaker level inputs.
Something like this;
https://www.parts-express.com/dayton-audio-sub-1000-10-100-watt-powered-subwoofer--300-628
Generally speaking this means a fault in the power output stage of the amp, which is the part in the pcb where the Output Transistors and the Aluminum Heatsink are, hope this helps.
hi.
Did you checked balanced impedance?load speaker impedance vs PA output?or PA might over driven,causing a trouble on the pre-amp to power amp circuits and components damage,
need to recheck related components on the pre-driver up to main output section,
Note: That,blowing of fuses with the same rating is an indication of trouble/shorted in a circuits that driven on it,
The good news is that it's in one channel, which means you have the right channel parts to compare it with. Now the bad news whatever causing it and it's likely to be a semi-conductor (transistor or IC) has to be replaced. However finding it is easier than you might think. For a start it's going to be hot to touch. And you can get get it to stop being hot, while the amps on, so correcting the fault, for a while. You do this by spraying it with Servisol Super Freezer spray. You have to have the amp running for this. Find the left channel amp and wait while it goes bad. Then spray (one at a time) any part you suspect. If the sound returns to normal, you have found the faulty part! To prove it spray the same in the right channel. That shouldn't change.
You can get the freezer spray from your local electric parts shop (such as Maplin UK).
That model shouldnt be stuck in stand-by
Are all the speakers connected?
If it wont properly turn on then there is a fault being detected. Could be disconnected speakers / bad speaker or a power supply issue
Sounds to me like a bad capacitor, but not sure. I would look inside for any slightly bulging capacitors or capacitors whose plastic wrappings have melted or shrunk or cracked (most caps are cylindrical). Please unplug first and be careful inside there and do not touch anything. I actually came across your post while looking for info on what I think is the same amp my brothers had but blew, and I was going to ask if they still had it so I could repair it. I've been very successful at repairing my electronic equipment such as Altec Lansing Model 95 speaker crossovers, power supply in Emu Emax II, and almost everything else in my studio.
