Garmin nuvi 1310 Car GPS Receiver Logo
Posted on Nov 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you in put a pre selected route in to the Garmin Nuvi 1310 GPS so that i can have the route in turn by turn before i leave home
perdue40
Level 3:
  • Garmin Master 589 Answers
  • Posted on Nov 11, 2010
perdue40
Garmin Master
Level 3:
Answers
589
Questions
0
Helped
122259
Points
1317
Sure and your doing the correct thing good thinking, always check the route before you go there are way to many ways to get there....
When you input the destination let it calculate then press the green bar on top where it says which way to turn.... it will then let you see which way its traveling, you can arrow down turn by turn or on bottom of screen press show map and give you the route highlighted with a green flag and checkered flag
I live in florida usa im going to israel? how do i set my garmin nuvi for roads in israel
Unfortunately Anything below the 1xxx series will not support mapping for isreal, so you may want to upgrade to the nuvi 1310 which come pre loaded with the mapping you need.
Hope this helps!
tip
Garmin Nuvi 1310 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1310 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
___________________________
Garmin Nuvi 1310 Manual Download
Garmin Nuvi 1310 QuickStart Download
Garmin Nuvi 1310 Favorites Backup
Garmin Nuvi 1310 Hard Reset
on Jun 18, 2010 • GPS
tip
Garmin Nuvi 1310 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
Would you like to back up a copy of your Garmin Nuvi 1310 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
______________________________________
1helpful
2answers
My Garmin Nuvi 1310 has no sound
Go to Tools.... Settings....Language....under Voice pick one that has a
Can I do route planning on my pc and then load it onto my Garmin nuvi 1310.
Mapquest will let you download your maps into your Garmin
On the Mapquest page sent it to ......you will see Garmin unit there
tip
Garmin Nuvi 1310 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1310 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1310 series GPS unit.
I hope that helps.
__________________________________________
tip
Download Garmin Nuvi 1310 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1310 GPS?
Would you like a digital copy of the Garmin Nuvi 1310 Users Guide for easy searching of terms and quick reference?
The Nuvi 1310 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
2answers
My nuvi 760 routes me the long way around
You should do the following: Changing the Navigation Settings;
Touch Tools>settings>Navigation. There you'll find how the sysytem will calculate your route.Route Preference.........Faster Time....Shorter Distance.......Off Road....Avoidances,very helpfull....Restore original navigation settings.
Hope this will help you,
JADF
My Garmin nuvi 205 will not give voice prompt
The germin nuvi 205 can be pre loaded specific data on the route and has voice. i dont know if yours has been pre loaded, with 3.5 navigation data.
tip
Download Garmin Nuvi 1310 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1310 GPS?
Would you like a digital copy of the Garmin Nuvi 1310 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1310 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
