Question about Mitsubishi WS-55511 55" Rear Projection Television
Green status light flashes 11 times then stops then does it again.Tv doesnt turn on.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Do me a favor, when set shuts off, press and hold menu and input buttons on front of set for five seconds and release both, light will blink a two digit error code, and repeat it several times, let me know error code and I will tell you what it means.
SD TECH
Posted on Nov 11, 2010
SOURCE:
Green light blinks 3 times
Hitachi p50s601 led blinks 3 times - YouTube
? 2:22
www.youtube.com/watch?v=xM6bpKK0LG0
Jun 28, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click ... flash, but when I remove both boards the TV just runs agreen solid led as if it .... It would show a static then go right back in the 3 blinking blue lights.
Apple TV: About the status light - Apple Support
https://support.apple.com/en-us/HT200154
Apple Inc.Apr 29, 2015 - The Apple TV status light (LED) glows steadily, flashes, or turns off. ...Flashes three times, Rejecting a command from the remote (you've ...
Oct 19, 2015 | Televison & Video
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
Jan 03, 2014 | Butterfly Toys
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red light stops...
this happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
SONY TRINITRON KV-28LS35U
Error 11 means the 8V supply is missing.
Check the power supply.
Jul 25, 2017 | Sony FD Trinitron WEGA KV-30HS510 30" TV
Right out of the box. doesnt work
Don't feel bad - these are cheap TV's and there are lots of problems with them. Just be glad it failed so soon that you can take it right back and get something more name brand this time.
Remember - always google the model number you are looking to buy (with either "repair" or "complaint" in the search) and you'll be less likely to buy an TV industry land mine.
Jan 24, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Mitsubishi WS-55511 55" Rear Projection Television Logo
52 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
