Water accumulate in vegetable try & vegetable get frozen , they smell differentWater accumulate in vegetable try & vegetable get frozen , they smell different
You can't post conmments that contain an email address.
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
hi there, refrigerators have condensation that forms and generally goes down a little hole that is usually under the fruit and vegetable drawers. This water should go down this whole into a condensation pan that is under the refrigerator and then evaporates. Sometimes food gets in the hole under the drawers and keeps the water from being able to travel where it needs to. Try to run a pipe cleaner of something through the hole to clean it out and maybe a very small amount of HOT water. If there is no hole there, it is unusual and it is possibly something else. This is usually the problem I have. Hope this helps!
it come from your freezer part , open the freezer back panel and check that the drain hole is clear and not fool with ice you can clean it with hair dryer but do it gently.
Look on the top back of ur fridge. in the middle of it u should see a resetacaple. if it is full of water and over flowing there is ur problem. then u have to check about ur cooling unith if not change the setting of u fridge let the frizzer frezze and the fridge stay a bit warmer
This is caused by a clogged drain tube or the door is not closing correctly. Be sure the seal around the fridge door is closing correctly. If not, the drain tube needs to be replaced or cleaned.
Hi, water could be excessive moisture, check door gasket, or check drain at back above veggie drawers, could be block, make sure produce not blocking drain hole, clean, check carefully for drain.
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted.
The seals are there to stop moist external air getting in then dropping its load of moisture as it cools.
A.
