http://www.bernina.com/de/SupportData/Out-of-Print-de/BERNINA_Serger_2000_manual If you view the book online, you can usually enlarge the view.
Easy Instructions for Threading Bernina Serger eHow Start out with NO thread in the machine.
ALWAYS RAISE the presser foot during the threading process.
When threading through the tension guide below the thread tree and through the tension disk, give each thread an extra little tug to make sure it is completely seated (it may even make a little popping sound when it seats).
ALWAYS THREAD each IN THE CORRECT ORDER (upper looper first, lower looper second, then the needles). When threading the lower looper, ALWAYS FINISH with the lower looper thread draped OVER THE TOP of the upper looper.
If a serger looper thread breaks, it is most often easier (and much less frustrating) to unthread the entire machine and start from the beginning. Trying to fish a thread through only works about 1% of the time, Just bite the bullet and do it!
When unthreading the machine, NEVER pull the thread UP through the tension disks! Instead, cut the thread below the thread tree, RAISE the presser foot and pull the cut threads down and out.
The Bernina Serger Workbook may be helpful, found here:
http://www.berninastore.com/workbooks.htm
My lower looper also breaks constantly. It seems the thread moves too far to the right of the slide out thread guide. It is very frustrating and I would appreciate any help.
the lower looper thread keeps breaking and the serger will not make a chain
