Replacing that motor is a very difficult process to get correct. It’s not just a swap out. You should absolutely have a professional do it.
1) Try to measure the if there are 110Vca in the terminal in forward or reverse.
2) Try to measure the ESR from Capacitor and replace it.
3) If you system as LIMIT Switch , test for continuity with DMM for faulty and replace, or some wires loose or disconnect.
4) If you system are Relais see if the relais for UP and down, and working most of them has LED that will be LIT indicating working or NOT
5) If NOT voltage Vca are NOT, coming from The Controller Board Motor, REPLACE IT,
Control board motor has 3 power supply: 1) Console board 2)Elevation Motor 3) Main Motor.
Some IGTBs are Defective.
Blessing.
[email protected]
cell+whatsAPP:+50588611441
LED Blink Patterns on the Control Board Treadmill
SOURCE: Hi! i have a life fitness 9500HR treadmill and it
Unplug the treadmill . Remove front cover. On the right hand side if you are facing the front - in the siderail is a white switch that tells the treadmill it is all the way down. Check that it is in place and clean.
If you plug the treadmill in.{Do not touch any thing in the motor compartment} When you press start it should go all the way down [home] to contact the switch. You can also see the lit motor turn at this time before the belt will move it must be all the way down.
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
SOURCE: Sir, i have a life fitness
please check the fuse of 0.3 amp is located in the front of the machine revises this swicth home underneath the left side of the machine or check for side always in the left if the cables are not disconnected last step and check the capacitor is located on the hoist motor any question send me a message [email protected]
