Mitsubishi WS-48313 48" Rear Projection HDTV-Ready Television Logo
Posted on Nov 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY REMOTE TURN THE TV ON, BUT IT TURN OF MY IT SELF. I CAN TURN THE TV ON BY POWER, BUT IT ALSO TURN IT SELF BACK OFF.
Anonymous
Level 3:
Top Expert:
  • Mitsubishi Master 14,553 Answers
  • Posted on Nov 10, 2010
Anonymous
Mitsubishi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718400
Points
48227
Do the self check this set has, when power light goes off, ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT (DEVICE) BUTTONS FOR AT LEAST FIVE SECONDS AND RELEASE BOTH.
Watch the power light, it will blink a two digit error code=====most common is two blinks, two blinks a pause and it will repeat the code several times.
This is to narrow down where the problem is.
Let me know what error code you find and I will tell you what it means.
SD TECH
How to I get the power only mode to go off if I do not have the remote control to my LG TV
turn it off manually on the telly or at the wall switch. Get yer self a universal remote from walmart for around $5.
Forgot my password I cant watch any channels
The easiest way is to reset the TV. There are 3 possible resets for this TV. press and hold Action and Power on the TV until self check appears-- then unplug the TV wait for 30 sec. then plug back in. The reset should take care of any channel lock/ game guard settings
Also Volume down on unit and sleep on remote. Same process wait for self check then unplug for 30 sec. plug back in and turn on.
Last Volume down on the unit and RH-Split on the remote-- same process
hope this will be helpfull. Please rates me . Goodluck...................
Why does your PANASONIC tv ask for a password?
or
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip
Turn off after a few hours
If the TV turn itself off then perform the following steps:
(i) Check if the Sleep timer is activated.
(ii) Check if the Parental Guide prohibits viewing during that time and/or limits amount of viewing time per day.
(iii) Check the batteries on your remote, low battery power may cause random signals from the remote.
(iv) Disconnect all the cables from the TV then reconnect them after a few hours.
(v) Ensure the power cord from the TV is directly connected to a functional wall outlet.
(vi) You may also try resetting the TV to the original factory settings by pressing the Reset button on the remote control supplied with the TV when in Menu.
The following is the information indicated by the blinking patter of the standby/timer lamp on the TV:
2 times : Power does not come on.
Load on power line shorted.
3 times : The TV has entered standby mode.
4 times : Has entered standby state after
horizontal raster.
Vertical deflection pulse is
stopped.
Power line is shorted, or
power supply is stopped.
5 times: No raster is generated.
CRT Cathode current detection
reference pulse output is small.
6 times: No picture
9 times : No sound
Furthermore, the TV is equipped with a self-diagnosis function that you can use to determine whether the issue is related to any hardware malfunctioning. Perform the step given below to run self diagnosis:
Quickly press the remote command button in the following order from the standby state.
Display -------> Channel 5 ---------> Volume -(minus) --------> Power ON.
If the Self Diagnosis display numeral "1" for any parameters then a fault has been detected and service will be required.
wish u good luck!!!!!!!!!!
4helpful
NO HDMI INPUT
1. Press "sleep" on remote so that "0mins" is displayed
2. press "video/video status" and "display" simultaneously to display service menu
3. go to "self check" menu. You need to go to "Digital Service" then "Self check" for some models.
4. Power off the TV while in self check mode
5. unplug tv then plug it back in
6. turn on TV and test the HDMI
1helpful
2answers
Dont have securtiy code to unlock tv
  1. Press and hold Action and Power on the TV until self check appears-- then unplug the TV wait for 30 sec. then plug back in.
  2.  Volume down on unit and sleep on remote. Same process wait for self check then unplug for 30 sec. plug back in and turn on.
  3. Volume down on the unit and RH-Split on the remote-- same process
Try these one at a time until you find the right one.
Let me know if this helps and please rate this solution. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
91helpful
2answers
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
15helpful
2answers
Turning off PIP without remote
To turn off the "stuck" pip on a Panasonic tv without a remote:
1) Turn off the tv.
2) Then hold down the "Action" button on the front of the tv and press the power button.
2-b) Continue to hold down the Action until the tv powers all the way up, and the reset menu comes up - be patient.
Expected Reslut: Self check menu should appear.
Expected Reslut: The pesky pip screen will be gone!
If the self check menu does not appear, you did not hold the Action button long enough.
Simply begin from step one.
Thanks to Imhiro
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
