Hello, when I insert a CD (normally purchased) into my Fiat Punto Grande stereo it displays "CD ERROR", ejects the CD then displays "AUX" (the tuner still works). I would be grateful if anyone has any idea what the problem is, thank you.
Yes that should work for you, you just need a cable that will convert the mini-stereo jack of the mp3 player to an RCA jack if the aux input is an RCA input. If it is the same 3.5mm size then you only need a 3.5 mm male to 3.5 mm make cable. Make sure when you first plug it in, the mp3 player volume is turned down low and you can adjust it higher after the is working for you. You don't want to input too big of a signal into the car stereo at first. then you should adjust it so that it is about the same volume as the radio is at. You don't want to blow up the amp ic in the radio or the pre-amp ic for the aux input.
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Don
