Question about Kenmore Sewing Machines
I got a 1950 sewing machine set in a table with a knee control for the pedal. The light comes on, but I am not sure how to make the knee pedal work. There is a lever and I have moved it, but nothing happens. What should I do next? Do I need to look at electrical connections? Do I need to move the lever to certain position?
    Genius:
  • 1,788 Answers
Have you tried getting a copy of the owners manual? You can usually download one for $10 at www.sewingmanuals.com or go through Sears. I remember having a machine with a knee control and it seems to me that you only had to pick your stitch length and press the knee control to make it sew. Mine was a straight stitch only Singer. Do some research online with your model number, google it and see what you find. Good luck
Posted on Nov 10, 2010
SOURCE:
I have an old brother Hz5 b1. Does anyone know that if this machine comes with a foot pedal? If so, where to get one? Thanks
There were generally 3 ways of running a sewing machine: foot treadle, knee control, or foot control. If yours has the plug for the foot control, take it to a local sewing machine shop and see if they can set you up with a foot control.
Dec 15, 2017 | Brother Sewing Machines
My riccar 555su machine starts sewing as soon as I plug in. Foot pedal is stationed inside cabinet by knee, but I'm not controlling it.
The pedal is stuck in the ON position. Unplug the sewing machine and try to open up the pedal to inspect it. Or try pressing the pedal a few time to loosen up the pedal movement. Good luck!.
Oct 24, 2016 | Riccar Sewing Machines
How do I slow the speed of the machine down in order to quilt
use a smaller stitch. DO NOT PUT YOUR FOOT ON THE PEDAL SO HARD
Jun 28, 2015 | Sewing Machines
Company recomendated any table to use sewing machine 1507
if it is an ordinary sewing machine then any old table will do
kitchen, dining , bedside any table that you can sit at with your knees under it
Jun 14, 2015 | Sewing Machines
Problem with knee lift
are you sure it is in all the way and it is far enough away from your table so it is not catching on anything ?hope this helps
Oct 16, 2014 | Janome Memory Craft 9000 Computerized...
My machine gergles and then the needle starts to vivbrate back and forth without touching the pedal. It seems like it starts doing this after it is on for a while.
The foot/knee control is hanging in the 'on' position slightly. Look for an adjustment screw on the control, something that will let you set the pedal position. Try to adjust it so as to have a tiny dead spot at the beginning of the pedal travel, so that you actually have to move the pedal a little before the machine starts.
lp
Jan 15, 2011 | Singer Sewing Machines
We have a very old Necchi Model BU Mira, that is integrated into a sewing table. It has a knee pressure speed control. There is no power cord, so I'm trying to figure out where to connect one. It appears...
The power wire (from the wall) connects to a block just under the motor where the on/off switch is. On my machine there is a brown block with the words Necchi italy on it. I unscrew two screw and there is a track were the power cord lays and leads bite in to the cord as the screws are retightened..... The blue wires from the transformer are on the "sewing machine side" of the transformer and power from the wall should not be attached there.
Dec 20, 2009 | Necchi Sewing Machines
Should there be a pedal with this machine (201K) purchased in 1953? What is the metal twisted bar for?
sounds like you have a cabinet model, yes this machine requires either a foot or knee control, the twisted metal is probably part of the knee control mechanism. order foot contrrol or knee control to fit the machine from linssewvac@hotmail.com
Sep 25, 2009 | Singer 132QRFB Mechanical Sewing Machine
Sewing Machines Logo
126 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
